Question about Hitachi CP-S210 Multimedia Projector
Red screen I have a red screen on a Hitachi 50V500A that can not be adjusted with on screen setting. How can i repair this? Thanks.
I had a similar problem with the same projector. Replacing the computer to projector solved it.
Posted on May 09, 2009
My Hitachi 50V500A has a large area where the color is turning out to red. Is this a lamp or a complete light engine replacement job?
not the lamp. hitachi knowingly had a defect with the fan not allowing enough air to cool the lamp which has burned the red color lense resulting in the red on your screen. enjoy your new brick thanks to hitachi!
Jan 09, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi ultravision 50V500A screen dim
The model indicated is a DLP rear projection and uses a "lamp" for brightness.
If it has not been changed for a while it should be on the right side of the set behind a removable plate. Check your owners manual if you have it.
Life span varies but 2,000 hours is normal.
Let me know if you need any further assistance as I am here to help.
SD TECH
May 14, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Blue streak and no red on Hitachi 50V500A rear projection TV
Check a second source such as a dvd player or game system using different cables. If the same issue happens then the tv will need repair. However if the issue is not the same it is either cables or the original source.
May 06, 2010 | Hitachi 60V500 60" Rear Projection...
I have a hitachi tv model number 50V500A the
go to the menu screen and select picture mode/menu and you should see the option to make changes to colors selection. You can also try and find one of your DVD's that has THX listed on the case. These DVD's have a calibration program included in the disc which can assist you with fixing the color issue
Nov 30, 2009 | Audio Players & Recorders
OUR HITACHI 50V500A HAS COLOR PROBLEMS WE MOVED IT
This is an LCD rear screen projection TV. There is a Red, Green and Blue LCD pallet that is mounted on what they call an X-cube. If all you are getting is Red and green then something happened to the blue pallet. Either the Ribbon connector came off or is loose or something worse. How hard did you mover it?
Another thought. How is it hooked up. If component then this may be the issue as component video connections are Red, Green and Blue. Just a thought.
Let me know.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Yellow Screen over most of the TV?
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 50UX57B 50" Rear Projection...
Red circle in middle of screen color is way off
You have a problem with the light engine. Hitachi has extended the warranty on some of these. This is a major expense with major labor charges. Better get in contact with a local Hitachi authorized repair facility.
Apr 30, 2009 | Televison & Video
Hitachi Class Action Lawsuit
I have a 60 inch lcd with the red cloud, bought the tv in 04 called hitachi about it and there sending my tv repair man the light engine no cost. Everyone just needs to call them again. thanks Jim
Aug 31, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red spot when screen is black
Your light engine will need to be replaced as you have a LCD panel failure. Here is the link to the part number for the model 50V500 if you have the 50V500A it has a different part number. http://www.partstore.com/ProductDetail.aspx?ProductSKU=8286849&ProductType=PART&ModelID=374014
Mar 14, 2007 | Hitachi 50VX500 Television
Hitachi CP-S210 Multimedia Projector Logo
421 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
