Question about Canon PIXMA MX310 All-In-One Printer
Installing ink How do i install new ink cartridge, i cannot get it over to the left side where it indicates it needs to be to change ink
  • Anonymous Nov 13, 2008
    CANT INSTALL INK AT ALL
  • Anonymous Jan 30, 2009
    mx310 printer cartridge -- how do i get the cartridges over to the left side to change them?
Do while it's turned on
Posted on Oct 30, 2008
3 Suggested Answers
seabelow
  • 95 Answers
SOURCE: low ink indicator light after installing new cartridge
go to the control panel, open printer, select your printer, then options, then maintance, somewhere you should see, Did you change the printer cartage? click yes.... close it up your done
Posted on Apr 03, 2010
  • 1218 Answers
SOURCE: hp printer model A909a indicated
Follow the instructions below to replace the printheads in the All-in-One product.
Video of replacing the printhead
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
Posted on Oct 06, 2010
HP 6700 printer change ink cartridge
http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put your fingers on the upper left hand side of the panel (by the logo: HP OfficeJet 6700 Premium), You should be able to gently pull the panel so that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
Aug 18, 2012 | HP Officejet 6700 Premium E-All-In-One
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Lost my manual, need to change the ink cartridge, help
    3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    Apr 24, 2010 | Lexmark C533DN InkJet Printer
    Low ink indicator light after installing new cartridge
    Apr 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    How to load new ink into printer Canon Pixma 620B ? Thank you!
    Step 1.
    Open the hood of your printer; if the ink cartridge holder does not slide into view, check to make sure the printer is turned on.
  • Step 2 Remove any empty cartridges from the ink cartridge holder and dispose of them properly. Some Canon printers have a protective cartridge lid that must be opened before you can change a cartridge.
  • Step 3 Remove all protective tape and plastic film from the fresh cartridge. Canon uses a bright orange protective tape on its ink cartridges. Some Canon ink cartridges also have a bright orange protective cap over the ink nozzle that must be removed before installation.
  • Step 4 Insert the new cartridge into the ink cartridge holder. Tilt the cartridge up slightly and insert end-first into the proper slot; push down gently on the cartridge to lock it into place. Some Canon printers have an indicator light that will activate when the cartridge is firmly installed; other models have a cartridge cover that will lock into place when closed.
  • Step 5 Close the hood of the printer. The printer will indicate when it is ready for use with a message on the LCD screen or by blinking the LED indicator light.
  • Jan 22, 2010 | Canon Office Equipment & Supplies
    How do you change the ink
    See the following URL for diagrams: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002072/Mini3_Mfc_Base_UsaEngUsr_B.pdf
    Open the ink cartridge cover, on the front right side. Pull the lock release lever down and take out the empty cartridge (it has a little ink left). Now open the bag containing the new cartridge and take out the cartridge. Take off the protective yellow cover and make sure you do not touch the area that was covered. Push the new cartridge into place; there is an arrow on the side that indicates the direction in which it goes into the printer. Lift up the lock release levers until each one clicks (as needed depending on the number you unlocked before). Close the ink cartridge cover and answer the queries about the new ink to clear the counter. The counter will be automatically reset if you wait to see Near Empty and Ink Empty on the LCD screen before you change the ink.
    If the LCD screen still reads Install, check that the cartridges are fully seated in their slots.
    I hope this helps.
    Jan 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
    I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
    To install your Brother machine#s ink cartridges, follow the steps
    listed below:
    1. Make sure that the Brother machine#s power is turned on.
    2. Open the ink cartridge cover. This cover is located on right-hand
    side of the Brother machine#s front panel.
    3. Pull down the four lock release levers. There is one lock release
    lever for each ink cartridge.
    4. Take the ink cartridge out of its protective bag.
    5. Carefully remove the yellow protective cap from the ink cartridge.
    - DO NOT touch the side of the ink cartridge covered by the yellow
    protective cap.
    - Take care when removing this cover to prevent spilling ink and
    staining your hands and clothing.
    - If the cartridge cover comes off when you open the bag, the cartridge
    will NOT be damaged.
    6. Install each ink cartridge in the direction of the arrow on the
    label.
    - Please note that each color has its own specific position. These
    positions are indicated by the colors of the four lock release levers.
    Do not install an ink cartridge in the incorrect position, as this can
    cause print quality problems.
    7. Lift each lock release lever and push it until it clicks into the
    closed position.
    8. Close the ink cartridge cover.
    - If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
    or #Install Yellow# after you install the ink cartridges, please verify
    that you have installed the cartridges correctly.
    NOTE:
    * DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
    * DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
    * DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
    * If you mix the colors by installing an ink cartridge in the wrong
    position, clean the print head several times after correcting the
    cartridge installation.
    * Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
    * Use unopened ink cartridges by the expiration date listed on the
    cartridge package.
    * DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
    Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
    Installing new cartridge
    Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
    Mar 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Faded left hand copies
    Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
    Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
    Canon PIXMA MX310 All-In-One Printer Logo
    47 people viewed this question
    old marine
    old marine
