Question about Brookstone Wireless Optical Mouse (400004965624)
Change batteries in brookstone mini mouse - Brookstone Wireless Optical Mouse (400004965624)
I can not get the Brookstone scanner mouse to install on a Windows 7 Professional Laptop?
Make sure you install with administrator privileges (right click run as administrator)
http://www.brookstone.com/webassets/downloads/ScannerMouse_817873/windows-driver_817873p.exe
why not disconnect the mouse and use the trackpad/buttons until it asks you to connect it?
Nov 13, 2014 | Brookstone Scanner Mouse
How to change batteries to mini optical mouse
There are no batteries. It's a wired USB mouse.
Apr 26, 2014 | iHome Optical Mini Travel Mouse W...
I have a Brookstone Wireless Mouse Model 535872 that is not responding... it has been awhile since I have used it but don't know how to change the battery or test if the battery needs changed
The most common problem with wireless mice and keyboards that makes them stop working is lack of calibration. To calibrate your mouse, you need to press the button on the mouse at the same time you press the button on the receiver which usually goes in your pc's usb port. Press and hold both buttons for 20 - 30 seconds and release them. See if that solves your problem. If it doesnt, then try changing the batteries and then calibrate as explained above.
Jul 12, 2011 | Computers & Internet
Brookstone wireless mouse
Connect your wireless mouse while your wired one is in the computer. Now, if there were any CDs that came with your mouse then put them in your CD reader and go through the installation process. If there were no CDs, then search online and find a driver the suits your mouse. Download it and install it.
Do not unplug your old mouse while installing the new one. You need something to use while you can't use the new one :P
Dec 31, 2009 | Brookstone Wireless Optical Mouse...
How do I hook the wireless mouse
2 AAA batteries go into the Mouse itself.
You plug in the USB transmitter into any USB port (Windows will recognize the install the proper drivers for you automatically).
The Mouse should have a SYNC button (push that button after you add the 2 AAA batteries and have plugged the USB transmitter into a USB port).
Dec 05, 2009 | Brookstone Wireless Optical Mouse...
How do I change the AAA batteries in my GE Wireless Optical Mini Mouse
Grip the sides of the mouse with both hands and slide the battery cover
back with both thumbs. Then, replace the old batteries with two AAA batteries. Replace the battery cover. Hope that helps.
Jul 30, 2009 | GE Wireless Optical Mini Mouse 3087897985
Change batteries
This is a deceptive little beastie. As you look at the mouse, you will see that the front approximately 1/3 consists of the left and right mouse buttons and the scroll wheel. The rest appears to be a one piece cover with the black area with the GE logo in the middle. There's the tricky part. The black part with the Logo is the housing for the USB plug in part (so you can keep it with the mouse when transporting it). The rest of that (silver on my mouse) is the battery cover. You open it up by gripping the little raised line on each side of the cover and pull backwards while holding the front by the black area under the mouse buttons. The cover (only the silver part, the black is attached to the rest of the mouse) will slide backwards and Voila! There are your batteries.
Jan 12, 2009 | GE Optical Mini Mouse ho98094
My USB plug in for my GE wireless optical mini mouse
There should be a button on the usb itself.You can try removing it plugging it back in then push that button if still red then you can try changing the batteries.
Dec 29, 2008 | GE Optical Mini Mouse ho98094
Change batteries in my wireless mouse
There should be a battery compartment on the bottom of your mouse. It might have a small screw holding it in place. Open & remove old battery, replace with fresh battery. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
Mouse
Do not use a mouse pad with this mini mouse. Battery will last much longer. I have had this mini mouse for about a year with no problems. Recently, though, after changing batteries, I found that the USB connector fails on and off. I have to pull out the USB connection and put it back in again. However, I am having to do this several times a day.
Oct 30, 2007 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
Top Brookstone Computers & Internet Experts
David Payne
David Payne
Are you a Brookstone Computer and Internet Expert? Answer questions, earn points and help others
