Question about LG Televison & Video
Mitsubishi wd-73838 green light flashing non stop
    Novelist:
  • 181 Answers
Hello!
that's very tough case! system block must be sent to "Mitsubishi" for rebuilding or replacement. Prepare yourself to spend about $500 for complete repair. Not "D.I.Y." project! A lot of parts and labor involved. Problem occurs, when quantity of bad electrolytic capacitors reaching it's critical point. there is the way to cheat, but you must replace all visibly "bloated" capacitors, first on every board, starting with power supply. If you decide to do so, get back to me after that. I will guide yourself through the rest of procedure.
thanks,
Alex.
Posted on Feb 16, 2012
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
  • 103 Answers
SOURCE: Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Posted on Apr 26, 2008
  • 13433 Answers
SOURCE: mitsubishi wd 52825 tv It wont
The flashing is a error code, how many times does it flash?
Posted on Jul 27, 2008
  • 179 Answers
SOURCE: Mitsubishi Mod. WD-52825 projection tv
9 times out of 10 it is not an easy fix. however ot is not an expensive fix either. checkout www.tv-techs.com
Posted on Dec 29, 2008
Mitsubishi WD 65837 Blinking green light, no picture. Error code 22
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 12, 2014 | Mitsubishi WD 65837 65 in. HDTV
My mitsubishi WD-65735 1080P has a green blinking light under the word lamp..what does that mean?
all these sets have a boot up if unplugged.
If power is lost or disconnected when reconnected green light will blink for about 70 seconds (set is rebooting) and then go off allowing set to be turned on.
Questions?
Mar 12, 2012 | Mitsubishi WD-65735 Television
The status light on a wd-73838 and a wd-65838 keeps flashing
the problem on this tv is the dm pcb , not the dmd , or may i say main signal board , also u can open the tv and chack for bad capacitors but if there is not bad capacitor you would need to replace the main pcb
Feb 12, 2012 | Mitsubishi WD-73838 73" HDTV-Ready DLP TV
How to set up an x box to the mitsubishi wd 73838
both should have a hdmi slot. This will carry both video and audio. If you don't have a hdmi cable, use component, the red, blue and green cable. The extra red and white go into the audio inputs on your television
Apr 06, 2011 | Televison & Video
Mishibishi tv 73838 diamoind series humming noise in the back
Your problem is most likely a defective color wheel. This part is an internal component of the optical engine. The V43 chassis has had an excessive amount of issues with the color wheel failure. Part number is 938P179010
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-73838 73" HDTV-Ready DLP TV
Replaced caps on tv worked then I turned off and now green light is flashing non-stop again. What's wrong now ? Please help
You'll have to check your standby voltages and make sure they are present. If they are not then the power supply needs repaired or replaced. Caps, as they are going bad can fatigue a power supply.
Dec 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
I have a mitsubishi tv model wd-52525 and the green timer light is flashing and it will not turn on. Just bought expensive bulb and replaced it and still blinking
Probley should check the DM board for bad capastors. DM board is inside of a metal case should be on left side of tv when looking from rear capastors should be marked 16v 1000 uF on them should be 4 of them about 1 inch tall green or black or blue or brown maybe even yellow in color if bulage on top then then thay are bad if not still could be bad common problem need to check may or may not be your problem does couse the power light to blink non stop.
Oct 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
214 people viewed this question
Computer Repairing
Computer Repairing
