Question about HP Pavilion dv4000 Notebook
My windows will not open
No vir All it shows is the hp logo Tries to open and then ask to start windows normal or las config or safe mode tried all Just repeats
  • joker197616 Oct 25, 2008
    Where is system restore located since i cannot open my start up menu.
I need to remove my bois passwords. I can change them but can not remove them to get to system restore.
Posted on Oct 28, 2008
Mine is f10 on hp dv 4000 when my screen starts up i push f10 and it flashs the menu like u said then goes straight to a bios password there is 3 of them that i have to put in after i put them in it starts all over. How do i turn off the bios password. i can change them but i cannot remove them if i could i will be abale to open the system restore.
    Problem Solver:
  • 18 Answers
Seems like you need to re-install Windows or use System Restore. Look in documentation how to do this, or post again for help.
Posted on Oct 25, 2008
  • Andrew Brown Oct 27, 2008
    I think for system restore you press F11 when starting computer, and you should get a menu for various options
System not booting normally
Its going to safe mode every time...actually Safe Mode is for to change any setting or get backup and some more... better to change the OS.. everything will be perfect after taking data backup... i think it will help u....
Apr 03, 2014 | HP ProBook 4510s FM849UT Notebook
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
Brought a advent 7113 2nd hand and it was working great but i was updating the windows programs/ however the computer stut down during and now its struck on a loop on the startup. giving options safe...
First try to boot with last know good setting if this doesn't work boot into safe mode and choose a system restore point and then retry you update again. Always be sure your laptop is plugged in when installing or doing updates, since if the battery dies in the middle of an installation or update your stuck like this.
May 19, 2011 | Computers & Internet
My hp mini 1000 wont boot up. when i turn it on it goes right to a screen that asks how i want to start up windows ( safe mode, safe mode with networking, safe mode with command prompts, and start windows...
hi blinkgirl556
was there a new hardware that was added to your laptop? bluescreens often are caused by hardware.
while the laptop is booting up when you are asked for options on how to start you computer is there an option for start windows using last known configuration? if there is try that and if it still goes into bluescreen you may want to try and recover your laptop using the hp recovery cd or recovery tool. if it still doesn't work most likely you have a bad memory chip.
hope this helps
contact me for any updates
janc30
Feb 08, 2011 | HP Mini 1000 Netbook
Acer aspire one
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
Mar 17, 2010 | Acer Aspire One PC Notebook
WILL NOT RUN
It's a hardware conflict,Have you recently update your ram or other hardware?
Is the fan running?
Have You tried to start in last known good configuration?
May 09, 2009 | Toshiba Satellite A55-S306 Notebook
Windows XP is not starting.
your operating system may have been corrupted , try 2 go 2 safe mode if you can and restore your computer at earlier time by system restore. if this doesnt solve your problem you can repair it using your installer.
Jan 27, 2009 | HP Compaq Presario C500t Notebook
Hp laptop
windows is thnking that you have a problem with the system
start windows in safe mode and troubleshoot and see what the problem is if all else fails you might have to to a system restore
or take it into a tech and see what they think
hope this helps
cheers
Jul 20, 2008 | HP Pavilion dv1000 Notebook
Hp pavillion trying to boot from dos mode
This is a common HP laptop problem.
Please try these steps, if they dont work you will have to do a restore.
Please let me know how you make out.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372724&cc=us&lc=en&dlc=en&product=1137817&dlc=en&lang=en
Dec 08, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion dv4000 Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
