Question about Sharp LC-32SB24U 32 in. LCD TV
So My TV went out and then the Power button was blinking for a while. Constant Blinking. I looked online and they said to Hold Power and Input at the same time then turn it on and it will only stay on for a few seconds. Well my TV is on and is staying on. but the power light is kind of orange yellow..what does this mean?
    Problem Solver:
  • 5 Answers
What kind of TV is it? If it is rear projection, you may need a new lamp.
Posted on Feb 16, 2012
  • trmc1469
    trmc1469 Feb 17, 2012
    Sharp 32" LCD Flatscreen Sharp LC-32SB24U 32 in
  • trmc1469
    Sharp LC-32SB24U 32 in Flatscreen LCD
Mitsubishi hdtv 1080 what are the blinking green light codes
ost models have a self-diagnosis feature to help determine shutdown problems.
To enable this feature do the following....
1) Turn the tv on and then let it shutdown
2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
This will commonly be one set of blinks followed by a short pause then another set of blinks.
This will repeat around five times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
2 - 3 = Deflection protect
2 - 4 = Vertical protect
Note: A constant blink on certain models will typically be caused by a fault in the DM model. To repair this check out site a "blinking green light kit"
Aug 05, 2014 | Mitsubishi WS-55513 55" Rear Projection...
Lc-40e67un sharp aquos. Power light is blinking in a constant rhythm with no variation. I tried the volume - and input reset. I saw a flash of the channel number and a gray screen for 1 second. Went right...
How many times do this standby light blinks at one time switch On? Count it carefully. These are called blinking codes, and from the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details about these blinking codes, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 23, 2013 | Sharp AQUOS LC-40E67U 40 in. LCD HDTV
Panasonic tv
Try couple of things .hold the volume button on the tv and at same time press the menu button rapidly 3 times.if this does not get into the correct screen try holding the volume button on tv and press the zero(0) button 3 times rapidly and another is to hold volume button on tv and press zer(0) button on remonte rapidly 3 times each o fthese methods these should get you into various set up screens but be careful and take notes if you change settings .you may have to unplug or turn power off at mains and power up again to see changes
Feb 16, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a 65611 Big Screen TV. The TV shut itself off. Pressed the reset button, It flashes green then off. Pressed power again and it just shuts off. Unplugged the tv and replugged. Have a power strip...
Hello it looks like you a problem with your main board, maybe a horizanal deflection. you can get the problem by run troubleshoot codes, first hold the buttons mune and input or device until starts blinking account the blinks, it will blink few times and the it will pause for a second again will blink. get blinking number like, 2 the 2, or 2 then3. that means 22 or 23. 22 means convergance problems. feel free to call me if you need more help with your tv. 602-810-7149 i live in mesa az
Dec 31, 2010 | Mitsubishi WS-65611 65" Rear Projection...
WS-55511 shut itself down while watching TV and won't come back on again. I tried unplugging and reconnecting, it goes through the reset (green light blinking). The convergence went bad and the chip was...
After you turn on and green power light comes on and then goes out:
Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it 4 more times.
Let me know what error code and I will tell you what it means. If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
When I push the power button, the TV starts to boot up (for about 3 seconds) then shuts back off.
It seems like you horizontal board and circuit may not be firing up. But, first you should try a different outlet and power strip and see if that resolves the problem. Back in my day the reset button always seem to do the trick , not any more and you may have tried that already.
Are you getting any light blinking? If so, can you tell me if it is blinking slow, fast, or what?
Can you see if it will blink back an error code? It really isn't to hard to do. Press the input and the menu at the same time, and hold them down for about 5 seconds. I'm sure it should have an input button but, you might have to use the power button instead. However, count the blinks and wait for a pause and then count the blinks again. This TV should give a two digit error code. If successful post a comment on what you were able to get.
The horizontal output has a few diodes that may have went bad. Or the DM could have troubles too. Let's pray a surge strip is all that is needed. I'll have to hold up until you respond for now just to see where it will lead us. I'll keep checking to see if you posted a comment so, that we can continue to troubleshoot this problem for you. Hopefully we can solve it fairly quickly.
Nov 02, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Toshiba 57h81 red light blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
Wd-52725
press the menu and input/device buttons on the front of the TV both in together and hold for 5 seconds to see if the LED will blink a two digit error code then let me know what it was. Please respond to this same post when replying.
Aug 09, 2008 | Mitsubishi Televison & Video
Sharp LC-32SB24U 32 in. LCD TV Logo
165 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
