Question about Lutron Skylark S-600P Light Control By
Lutron skylark s-600 p dimmer doesnt work all the time why?
2 Suggested Answers
  • 864 Answers
SOURCE: lutron skylark s-10p 1000w dimmer. why is one
This video from the Lutron site shows the Diva switch but it is the video for the Skylark single pole switch also. It makes no mention of one wire being a larger gauge and does not differentiate which wire connects to line power and which to load. I do not think the wire gauge makes any difference.
Posted on Aug 11, 2009
Lutron s-600 don't seem to function
That switch says on it that it is for fluorescent lights only. I don't know if you can use compact fluorescent bulbs on that system, perhaps verify if you can or not. The switch has electronics in it and may need that ground wire to get 120 volts to operate. If you have incondescent light bulbs return and get the correct dimmer.
Mar 16, 2013 | Lutron S-600-wh Skylark Incandescent...
Lutron 1000w skylark s-103p. The lights hooked up to this dimmer had always worked. now sometimes when i hit the on buttom they don't come on at all. the dimmer is probably5 years old.What do you...
Older dimmer switches use rheostats to adjust the resistant loads on the switch. Since this is a mechanical operation, over time they become loose or corroded. So it sounds like this has happened to your dimmer switch and you should replace it with a more modern switch that isn't as mechanical.
Jun 26, 2011 | Lutron SKYLARK S-103P Light Control by...
I have a lutron skylark s-600-wh. I would like to know if this dimmer is electronic or magnetic??? I will use it for a series of under the counter kitchen puck lights, and was told that the dimmer...
It is neither - it is rated for incandescent lamps only. It sounds like someone suggested that your puck ligths are being controlled by electronic low-voltage transformers, in which case, if you wanted to stick to the Skylark family, should be an SELV-300P-WH.
If you're not sure about any of this, I suggest calling Lutron's tech support line. It's at 1-800-523-9466, they're available 24/7, and can double-check the recommendation.
Feb 21, 2011 | Lutron S-600-wh Skylark Incandescent...
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
We have an older maestro style lutron dimmer switch with a horizontal slide button at the bottom that can turn it on and off. we are using this button to operate the light b/c the vertical...
These in-wall devices stop working and need to be replaced from time to time.
There are no repair parts.
Generally dimmers don't last as long as ordinary light switch, because they are electronic instead of mechanical.
Lutron makes the widest selection of dimmers.
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Use link above to identify dimmer.
For example Skylark dimmer.
Then google search for a replacement.
For example: single pole 600 watt lutron skylark dimmer
Or: 3-way 600 watt skylark dimmer
Lutron also makes 1800 watt dimmers for larger loads.
Add a comment any time if you need more help.
You can also take advantage of fixya phone service.
Fixya expert will talk with you via phone for a price.
Dec 24, 2010 | Lutron Electrical Supplies
Have a thyrocon dimmer, says on the bottom, 0180, also 600 w single gang, 500 w two gang, and 400 w three gang, 120 ac volt, the top that turns the dimmer on and off broke, went to Lowe's and Home Depot,...
Lutron shows widest selection of dimmers.
The wattages you posted are standard for multiple dimmers.
Once you identify type of dimmer, add a comment and say if dimmer is single-pole or 3-way.
A 3-way dimmer would be in a hallway, where more than 1 device controls same lights.
Single pole is where one device controls lights.
If I know what dimmer you have, I can search for the product and add another comment.
Or search for yourself:
For example, let's say you have 3-way Skylark dimmer.
Do a google search for 3-way skylark dimmer:
http://www.google.com/search?q=3-way+skylark+dimmer&ie=u
Or 3-way rotary dimmer, etc.
If information above doesn't help, then take advantage of fixya phone service.
Fixya expert can talk with you over the phone for a price.
Dec 22, 2010 | Solar Carlon Thyrocon Dimmer Controls...
Replaced existing Lutron skylark low voltage dimmer
You will need to return the 3-way dimmer and get a single pole dimmer, as the Lutron Skylark series is suspectible to failure if connected to a live circuit first, or misconnected at intial installation. As an electrician, I ceased using these dimmers years ago, due to the rash of call-backs by customers and went with Leviton togglers and have had excellent results.
If you purchased it at a 'big box' store, they will accept the return as a defective item, as they have national agreements with their suppliers to accept customer returns. Just tell them it didn't work and you want a store credit, you can then purchase the lower priced single pole dimmer you need and save some money in the process too.
Hope you find this Very Helpful - best regards!
Aug 18, 2009 | Lutron Electrical Supplies
Lutron skylark s-10p 1000w dimmer. why is one
Aug 11, 2009 | Lutron 1000-Watt Incandescent Dimmer...
It stopped dimming. Lights stay on full power
This is not a serviceable item. If this is the only switch in the circuit, then there is no further troubleshooting to consider. The dimmer simply needs to be replaced.
Aug 08, 2009 | AMS Lutron S-600PNL Skylark Single-pole...
Lutron Skylark S-600P Light Control By Logo
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
