Question about Briggs & Stratton Measuring Tools & Sensors
My engine will not stay running until it gets warm, then it runs normal. Could this be a govener problem
Checked spark and rebuidt carb.
    Problem Solver:
  • 9 Answers
Check for blown head gasket or leak at block to carb .Check head bolt s for proper torque .If it were a govener problem it over rev or surge .
Posted on Feb 18, 2012
3 Suggested Answers
  • 274 Answers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
SOURCE: won't stay running
I took the carb apart and found that it needed rebuilt, I installed the new carb and fuel pump kit and it runs great again.
Posted on Apr 06, 2010
I tried the coil that didn't solve it
Look at this forum for tractors.
I hope it helps you!
http://www.tractorforum.com/f192/ih-674-78bhp-running-under-load-issues-17715/
Another thing that can cause this is the carb. It may be getting too much fuel once it's warmed up. An engine needs more fuel when it's cold than it does when it's warm. Cold engines run inefficiently so they need more raw fuel to fire-up, and stay running. This is all a choke does. A choke plate closes-off the air going into the carb which makes the fuel mixture really rich so it can run. Less air = more fuel. You'll also notice that cars with chokes also idle real high until they warm-up. This fast idle and the over rich mixture (due to lack of air), allows the engine to fire up and stay running. As the engine warms-up and starts burning fuel more efficiently, the choke plate begins to open, which slowly lets more air in and leans-out the air/fuel mixture. Once the engine is warmed-up, the choke plate will be wide open allowing the carb to run as it is supposed to with the correct metering of fuel and air.
Jun 11, 2015 | Cars & Trucks
Choke has to be out to stay running, yet it speeds up on its own or dies
Sounds like the carb's need cleaned. If the jets are plugged partly off it can't get enough fuel unless the choke is on. Normally if the choke is on the engine will run a little faster, at least until it is warmed up.
Sep 28, 2014 | Motorcycles
Hedge trimmer does not stay on
Will it start & run OK, does it stop after it gets hot then will restart & run again when it cools untill it warms up then stops again,it yes it can be a bad coil,I had this problem on a leaf blower.sometimes just testing for spark won't help you out it may still have spark but the electronics inside the coil that controls spark timing goes bad you could still have spark but it's out of time so the engine still won't run if you suspect this problem change the coil,bad coils can also make them hard to start.good luck
Mar 06, 2014 | Weedeater Gas Powered Hedgetrimmer...
Husky generator will not stay running
Let the engine warm up for a couple of minutes and see if it will run with the choke off. I have a couple of small engines which crank well and won't run cold but do OK after I let them warm up a bit.
Normally I would say you have a carb problem with gas not getting from the carb bowl, into the jet and into the engine.
Your engine being new it could still be a problem.
All the air coming into an engine is supposed to come thru the carb. If you have air leaking in from somewhere else then to get the air/fuel correct enough to run you are having to close the choke.
Check for leaks by cranking the engine and doing a quick spray of carb cleaner all around the mounting areas but not near the air intake.
If there is an air leak the engine will respond by changing rpm.
If you don't find an air leak, it's the carb.
Jan 27, 2018 | Electrical Supplies
When the motor is cold and the outside temperature is below 70 the car will not stay running. Will die with in 30 seconds or so of starting, then you have to wait a minute or two befor the car will start...
Are there any service engine soon lights on associated with this problem?
Possible CTS (Coolant Temperature Sensor) or another sensor giving faulty data for the cool air temperature.
Check spark and gas delivery when cool, below 70 deg. If the spark is not being delivered or the fuel injectors are not delivering fuel at this temperature, it will explain why it doesn't run right until it is warmed up.
Oct 08, 2010 | 2001 Ford Windstar
Timing Adjustment issues!
If the bike runs then Top Dead Center (TDC) is not an issue. But to check piston stroke position, Remove the valve cap cover on the intake of the front cylinder. Remove both the spark plugs. Rotate the crank shaft untill the rocker arm starts to move. The piston is now starting down on the intake stroke. Rotate the crank further and the rocker arm moves in the opposite direction. The piston is now going upward on the compression stroke. Look at the marks on the flywheel. Rotate the crank untill the TDC mark lines up with the timing index mark. The front piston is now at TDC.
If your model has carbs then the backfire fix requires you to syncronize and balance the carbs.
SYNCHRONIZE THE CARBS
Remove the air filter and rubber fittings to allow you to see into the throat of both carbs. You may need a mirror to see inside. You need to be able to see the slides go up and down when you twist the throttle. Now turn the fitting where the cable goes into each carb such that there is just a bit of slack in the cable, 1/16" is plenty. Lock ONE of the cable adjusters down tight. All further adjustments will be made on the other carb.
With the motor turned off twist the throttle very slowly while looking at the slides. Both slides need to begin lifting at the exact same moment. If the slides don't raise at the exact same time then slowly twist the throttle until the locked adjuster slide just barely starts to move. Hold the throttle still and turn the adjuster on the other carb so that the slide on that carb just barely starts to move also. Now recheck the slide movement timing. Do this process until the slides on both carbs begin to raise at the EXACT same moment. Lock down the loose adjuster and re-check the slides.
BALANCE THE CARBS
Turn the throttle screw on the LEFT carb one half turn inward. Now start the engine and get it warmed up. With the engine running, remove the RIGHT spark plug wire. Adjust the idle speed on the left carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Now turn the throttle screw on the RIGHT carb one half turn inward. Restart and rev the engine. Next, remove the LEFT spark plug wire. Adjust the idle speed on the right carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Turn the idle screw on each carb EXACTLY ONE QUARTER turn outward and restart the engine. The engine will be probably be idling very fast. Adjust both the idle screws equally from this point to get to the desired idle speed. Congratulations, you have just balanced and synchronized your carbs.
Please rate this solution. Thanks sgtswampdonk!
Apr 02, 2009 | 1999 kawasaki VN 800 Vulcan Classic
Honda 1300c backfire through carb at wide open throttle. I have open up the exhust and rejetted the carb . the bike will run fine up to mid throttle or 65 mph but if you accellerate hard or go to wide open...
Try balancing ans syncronising the carbs.
BALANCE THE CARBS
Please rate this solution. Thanks!
Mar 30, 2009 | 2004 Honda VTX 1300
Raptor 660 idles but no throtle response
Turn off the gas and remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Get a set of the stock NGK spark plugs your bike came with. Check for spark on each cylinder before installing the plugs.
Now go to the idle and air screws on the outside of each of the carbs. IMPORTANT > > GENTLY turn both screws all the way in until they LIGHTLY seat. Now turn the screws EXACTLY one and one half turns outward.
BALANCE THE CARBS
Turn the idle screw on each carb EXACTLY ONE QUARTER turn outward and restart the engine. The engine will be probably be idling very fast. Adjust both the idle screws equally from this point to get to the desired idle speed. Congratulations, you have just synchronized and balanced your carbs.
PLEASE RATE THIS SOLUTION. Thanks!
Mar 28, 2009 | 2001 Yamaha XTZ 660
When car is cold it seemingly runs on 3 cylinders
seem like you got the same problem as my scion xa, check the fuel pressure regulater. bad regulater some time smell like leak gas. auto zone might cause you about $80.00.
Feb 09, 2009 | 1992 Honda Accord
Measuring Tools & Sensors Logo
184 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
