Question about Keurig B60 Coffee Maker
How to release j hooks on keurig B60 model - Keurig B60 Coffee Maker
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
  • 28 Answers
SOURCE: keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Posted on Feb 07, 2010
  • 10865 Answers
SOURCE: The brewcover on my Keurig B60 broke. Both screw
Hi. go to keurig.com/parts and order what u need. J.
Posted on Jul 25, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
Keurig B60 screen flashes "Not Ready," "Auto Set Off" and "Brew Temp." The machine also will not shut off. Unplugging it does nothing, nor does the reset sequence of button pushing. Is there anything else...
Lots of problems with the B60/65/70 units. There are some really good videos on you tube, but trust me, the process to fix is going to be a pain and cost ~$50. You should consider taking yours back for an exchange. There is a known problem with these models and it appears the retailers are being very generous on exchanges (check this out: http://babelniche.wordpress.com/2012/03/10/keurig-dumps-inventor-builds-millions-of-junk-coffee-makers/) .... Good luck
Nov 22, 2013 | Keurig Platinum B70 Coffee Maker
Keurig model b60 display not working not making coffee
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 01, 2011 | Keurig B60 Coffee Maker
Where to find K-Cup assembly for Keurig B60 model
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Jul 04, 2011 | Keurig B60 Coffee Maker
Need a valve for a model B60. are both valves the same ?
heatman101
Jun 19, 2011 | Keurig Special Edition B60 Coffee Maker
My kuerig doesnt release water into cup what could be wrong
heatman101
Apr 03, 2011 | Keurig B60 Coffee Maker
My 4 year old Keurig B60 just keeps saying "not
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 19, 2011 | Keurig B60 Coffee Maker
I have a Keurig Model B60 and everytime I use the "My K cup" it leaks terribly. Is there a fix for this?
heatman101
Jan 04, 2011 | Keurig B60 Coffee Maker
Jul 25, 2010 | Keurig Special Edition B60 Coffee Maker
Keruig Coffee maker (B60)
Keurig alluded to the fact that it is the heating element that buring out and causing these problems.
Oct 25, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
78 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
