Question about Coffee Makers & Espresso Machines
Krups kt406 will not brew. light comes on for 3 seconds and then automatically turns off.
Http://www.ereplacementparts.com/krups-kt4065505ca-dahlstrom-therm-timer-coffee-maker-parts-c-144838_144839_300018.html
Replacement parts! Search the website for your exact model. Mine was the kt406550 /5ca. You can find it on the bottom of the machine.
Posted on Mar 17, 2015
SOURCE: Krups Coffee pot stopped brewing after programming
OH Yeah!
That is the number one failure in these machines. (owned four of them)
The problem is one or both of the "twin" thermal fuses or the thermostat for water
heating and hotplate,( one in the same) has gone open. I have tried for a long time to locate correct replacement parts to no avail. I would STRONGLY not recommend trying to bypass as these are not only controls but a safety feature as well. I was lucky a wile back and found one without a carafe at a garage sale. used it for parts, now those have failed also. Really miss them. If I ever find a source for parts I will post it here with replacement procedure.
EfACTOR
Posted on Jun 13, 2009
SOURCE: My Krups won't brew
had the same type of problem with a hair dryer once. A thermal interrupter- I called it a planned obsolescence gizmo- died. I bypassed it with a silver wire soldered in and the hair dryer ran well until another part died years later!! Sailorb
Posted on Sep 14, 2008
EsWorld
  • 1618 Answers
SOURCE: Espresso brews too fast on Krups XP4030
Check/adjust the grind on your coffee.
Posted on Jun 24, 2009
  • 17 Answers
SOURCE: Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Posted on Dec 22, 2009
Sebin
  • 712 Answers
SOURCE: Krups FMF5 coffeemaker- coffeemaker begins to brew
Check for any blocks in the route of water from the reservoir. And do not try to run the machine several times before the problem is rectified. It may cause further damage.
Posted on Oct 08, 2010
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Xp9000 does not in form me that it has run out of beans, any help please , thanks
They only know that the beans is empty when it comes to compressing the grounds into a puck just before brewing. If the brew unit has nothing in the chamber to compress then it assumes you are out of beans.. Remove and thoroughly clean the brew unit and make sure grounds are exiting the grinder when the grinder is running.
Oct 19, 2014 | Krups Super Automatic XP 9000 Espresso...
Krups km406 will not brew coffee
could be clogged pump or bad pump, I have also seen where you need to let the water reach a certain temp. before it will begin to brew
Jul 14, 2012 | Krups KM4065 12-Cup Coffee Maker
This is the Krups Grind and Blue Coffee Maker purchased from Amazon 7/8/11. It is the second one I purchased. Krups factory service AND local service station phone lines are constantly busy. On this...
Sorry for the delay. I will need to look up some reference materials and drawings on this before I can aupply an acurate answer. Been one of those nights and I apoligize for the delay.
Sep 30, 2011 | Krups KM7000
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
Jun 21, 2009 | Krups XP4030 Espresso Machine
Water remains in filter basket after brewing
Behind automat(machine side ) it gets clogged with grinds. Clean it with air hose. If that don't work, change the o-ring on automat.
Feb 15, 2009 | Krups Caffe Centro 888 Coffee Maker,...
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
Krups XP 2070
I have the same problem and this is the second machine. I warrantied the first one because it stopped working. I brewed one espresso with this machine and now no water or steam will come out. Help?
Dec 23, 2007 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee Makers & Espresso Machines Logo
124 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
