I can't boot bootable usb from it what to do?
I am trying to bootable windows xp from it i have done all bios setup but i have read much of it and it seems that this facility is not available on windows xp.Please kindly help me please.
  • Paul Bade Feb 17, 2012
    How did you install Windows XP on the USB drive?
  • 32,281 Answers
If your BIOS does not have in the boot up device order the USB then the computer cannot boot up with an USB memory device.
In this case Windows XP cannot enable an USB port until Windows is up and running.
Posted on Feb 16, 2012
SOURCE: No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Posted on Sep 25, 2008
Geekman
  • 32281 Answers
SOURCE: Unable to open BIOS Setup
Are you trying to change the boot up drives so that the CD boots up first so you can do a repair or reinstall Windows?
Try F2
You can select from a list of bootable devices by pressing F12
Posted on Jan 01, 2009
Fixe_You
  • 1800 Answers
SOURCE: i can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Posted on Jan 27, 2009
pagebor
  • 2785 Answers
SOURCE: Lenovo laptop not booting from any CD, But able to read other Cds
you can check by disabling all other driver to boot except from cd rom. if it fails again then try with a new bootable cd written in low speed, if still it fails then try with a new rom
Posted on Jun 25, 2009
  • 11800 Answers
SOURCE: 'No bootable devices
No bootable devices = the hard disk appears empty, either Windows was corrupted or the hard disk has died.
Reinstall. If the install fails to complete or the problem comes back the hd is dead = replace it.
Posted on May 01, 2010
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
How to boot windows xp from pen drive
http://techgage.com/article/creating-bootable-windows-xp-7-8-flash-drive-installers/
Aug 24, 2014 | Microsoft Windows XP Professional
Asus n50vc won't install windows 7 from USB device
Try bringing up the boot menu (it will say what key to press on the splash screen) and choosing the usb. if that does not work try moving ports.
Jan 16, 2013 | ASUS N50Vc-B3WM PC Notebook
Bootmgr is missing
Take one bootable windows cd rom , insert the cd rom in cd rom drive, restart your Laptop , go to bios setup and select boot from cd rom after then save and exit . your Laptop will boot from cd rom . it will take some time , when you will see action prompt , select R ( if your bootable windows cd rom is SP2 ) , select D ( if your bootable windows cd rom is SP3) . if you select R you will be prompt repair consoul , format C:\ then instal windows SP2 . if you select D , you will be prompt delite partition , delite partition C:\ after then select C to creat partition and install windows SP3. either of one windows install like that and problem will be solved. n.b. if you don,t have cd rom drive pls collect USB cd rom drive.
Jul 30, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
I foprgot my pasword and sign up with a. differen t password and it still does not work can u help me
If you are referring to your Computer Password and as long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP.
Here's how with a step-by-step description of the initial Repair process.
1. Place your Windows XP CD in your cd-rom and start your computer (it's assumed here that your XP CD is bootable - as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be "Press any key to boot from cd"
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like "If one of the following Windows XP installations is damaged, Setup can try to repair it"
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically - you will see a progress bar stating "Your computer will reboot in 15 seconds"
9. During the reboot, do not make the mistake of "pressing any key" to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you've made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Apr 12, 2011 | Computers & Internet
Hi i wanna install win xp via pen drive to my pc
Go to BIOS setup the do
first boot from USB Drive then Restart you system. then automatically boot windows xp from your pen drive. Do and enjoy with windows xp. For this you need to get a Bootable Pen Drive http://files.extremeoverclocking.com/file.php?f=196
Here is the Tutorial to Installing Microsoft Windows XP from USB
http://compupodia.blogspot.com/2009/08/installing-microsoft-windows-xp-from.html
Sep 20, 2009 | HP Pavilion dv6000z Notebook
Jun 25, 2009 | IBM Computers & Internet
Booting
first connect ur usb then boot form cdrom drive installed windows in ur usb drive go to ur bios setup and make first boot device as usb boot enable
Dec 15, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
