Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Filter the red filter light comes on but i do not use the water nor do i make ice because it is not connectrd i only yse yhe fridge to cool and freeze things what's my problem?
  • 750 Answers
Hello culmer4
You wrote, the red filter light comes on but i do not use the water nor do i make ice because it is not connectrd i only yse yhe fridge to cool and freeze things what's my problem?
If you do not have the water connected then the light only went on to remind you to change the filter because of the time that lapsed since you started your fridge.
If you do not use it or need it do not change it and you are okay.
Then it means nothing to you and will not harm anything being lit.You are safe.
So your worries are solved.
Thank You Huuum
Please remember to leave a rating
Posted on Oct 25, 2008
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Sep 17, 2013 | Freezers
RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Ice maker is not producing ice. Replaced the water filter
  1. It may be turned off. Check the Ice maker shutoff arm located at the top of the ice bin. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, simply lower the wire.
  2. Is there water in the ice cube tray? If not check for water to the water valve. If you have water then it could be either a failed fill valve or ice maker control module is not activating the water valve.
  3. Check for pinched water supply line (behind the fridge)
  4. Do you have an inline water filter? If so, when was it changed last? To test if it is plugged, check for water both before and after the filter system.
  5. Sometimes the water inlet tube that directs water into the ice cube tray freezes over; this can often be thawed out by simply using a hair blow dryer and warming the area (be careful not to overheat the plastics as they can warp or crack). Then adjust the freezer to a slightly warmer setting and make sure water is not constantly dripping from the inlet tube, as it will only freeze over again.
  6. If it continues to drip we may need to replace the water control valve.
  7. The ice maker head assembly may have broken parts. Look to see if the gears are broken.
  8. Check to see if the small plastic arms that rest against the ice rake are broken.
  9. If the ice maker head assembly is modular and you've found broken parts,
Nov 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Ivan
Oct 08, 2007 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
