Question about Vehicle Parts & Accessories
Replace a automatic transmission on a 2000 toyota camryWhat's your problem?
4 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 1915 Answers
SOURCE: Rebuild 2000 Pontiac Grand Am 4T40E &4T45E
If it happened to me, I'd first check the shift cable and/or trans pawl to see if I had it properly aligned
Posted on Jun 23, 2011
  • 697 Answers
SOURCE: 2000 toyota echo, transmission won't shift to 4th
With such a small engine, the automatic Echo won't shift into overdrive (4th gear) until a certain engine/transmission temperature is reached. This is to protect the bearings and gears from too much torque and stress while the oil is still cold and not flowing at it's optimum level. Usually when the blue "cold" light on the dash shuts off, the transmission will up-shift to 4th. When it is very cold, it could take another few minutes of driving before it will do so.
Posted on May 05, 2012
eric_b_nevil
SOURCE: 2000 toyota celica transmission replacement
buy my 6 spd 800 dollars obo send your best offer tranny is in Reno Nv area but will deliver to Sac for 100 dollars but will require a 200 dollar non refundable deposit prior to delivery
Posted on Apr 01, 2013
My 99 Buick LeSabre has been working fine - drove it and parked it but when I went to drive it again it starts just fine but will not go in to reverse /forward or any gear. Had no problems previous t
NO REVERSE ON TRANSMISSION
It
can be issue with gears or problem with transmission and needs to be rebuilt.
Also get the tranny fluid checked. If it\'s low, then such problems
occurs.
To
troubleshoot these types of issues, check the actual solved problems with these
types of issues.
There
are solved help links provided below: -------
Click
the link below and go through the details and diagrams to troubleshoot the problem:
2003 Lexus RX300:
Transmission Fluid Burnt Brown and not Shift to reverse?
http://whatisbyme.blogspot.in/2012/05/2003-lexus-rx300-transmission-fluid.html
2007 Chrysler 300: Transmission Stuck in Park?
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
2000 Toyota Camry:
Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
1996 Toyota Corolla: Transmission
Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
CV AXLE stuck in Transmission?
http://technoanswers.blogspot.in/2012/04/cv-axle-stuck-in-transmission.html
Transmission in reverse,
acts like it\'s in neutral?
http://schematicsdiagram.blogspot.in/2012/04/transmission-in-reverse-acts-like-its.html
Delayed shift and harsh
Shifting?
http://schematicsdiagram.blogspot.in/2012/04/delayed-shift-and-harsh-shifting.html
Dodge neon wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Dodge Automatic transmission will not go into
reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Dodge manual transmission will not go in
reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
1998 Dodge Ram: Not Shift
To Reverse?
http://schematicsdiagram.blogspot.in/2012/06/1998-dodge-ram-not-shift-to-reverse.html
Transmission leak on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/transmission-leak-on-toyota.html
Automatic transmission,
with no reverse?
http://howtobyme.blogspot.in/2012/02/automatic-transmission-with-no-reverse.html
No Movement When
Transmission is Shifted to Drive or Third?
http://schematicsdiagram.blogspot.in/2012/03/no-movement-when-transmission-is.html
While going in reverse mode
Fuse number 27 blows on Ford Ranger?
http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
These
will help.
Thanks.
Nov 28, 2012 | 1999 Buick LeSabre
Manual transmission stuck in Nutural
It
occurs.
To
types of issues.
There
Click
2003 Lexus RX300:
2000 Toyota Camry:
Shifting?
reverse?
reverse gear?
To Reverse?
with no reverse?
No Movement When
These
will help.
Thanks.
Nov 27, 2012 | 1993 Dodge Dakota
2006 Hyundai Sonota will not go in reverse
It
occurs.
To
types of issues.
There
Click
2003 Lexus RX300:
2000 Toyota Camry:
Shifting?
reverse?
reverse gear?
To Reverse?
with no reverse?
No Movement When
These
will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
2001 mazda transmission problems will not catch a gear
It
occurs.
To
types of issues.
There
Click
2003 Lexus RX300:
2000 Toyota Camry:
Shifting?
reverse?
reverse gear?
To Reverse?
with no reverse?
No Movement When
These
will help.
Thanks.
How many litters or quarters of oil in transmision need a toyota corolla 2000?
Check your Trans model...
Change only - 2.6 quarts. Total refill - 6.1 quarts.
Transmission model A131L
19554
Application: With automatic transmission
Note : A131L transmissionCoastal Dexron VI ATF
06812
Note : A131L transmissionCastrol High Mileage ATF
19509
Note : A131L transmissionCoastal Dexmerc ATF 5 Gallon
Transmission model A245E
Transmission Fluid Type/Capacity
159920
Note : A245E transmissionPennzoil Multi Vehicle ATF
VV353
Note : A245E transmissionValvoline Dex/Merc ATF
Good luck.
Apr 25, 2011 | 2000 Toyota Corolla
What is the transmission capacity of a 85 Toyota Corolla?
Automatic Transmission Fluid - Volume: 2.50QTS. ( 2.4L ) - [Automatic Transmission Fluid DEXRON II] - 1.6L Eng & 1.8L Eng
Manual Transmission Fluid - Volume: 1.80QTS. ( 1.7L ) - [API - GL-4 or GL-5 SAE 75W-90 or 80W-90] - 1.6L Eng & 1.8L Eng
Feb 08, 2011 | 1985 Toyota Corolla 2 Door
Gear shift lever will not engage automatic transmission. it feels as though it is disconnected
2000 toyota camry gear shift lever will not engage automatic transmission. it feels as though it is disconnected
Sep 26, 2010 | 2000 Toyota Camry
First thing to do is check the fluid level if that ok you may want to think about having the transmission filter and fluid changed, there are other possibilities but check these first
Mar 17, 2009 | 2000 Toyota ECHO
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
