Question about Motorola GP88 Two Way Radio.
How to transfer from high power to low power - Motorola GP88 Two Way Radio.
Where is the four wheel module located on a 2001 f350 7.3 l lariat 4x4 nothing on the four wheel drive works and I checked all the fuses and are all fine
Have it check for DTC'S - diagnostic trouble codes ?
GEM Diagnostic Trouble Code (DTC) Index
GEM Diagnostic Trouble Code (DTC) Index DTC Description Source Action C1728 Transfer Case Unable to Transition Between 2H and 4H GEM CARRY OUT the electronic shift function test. REFER to Function Test - Electronic Shift in this section. C1729 Transfer Case Unable to Transition Between 4H and 4L GEM CARRY OUT the electronic shift function test. REFER to Function Test - Electronic Shift in this section. P0500 Vehicle Speed Sensor (VSS) Malfunction GEM GO to Pinpoint Test F . P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure GEM GO to Pinpoint Test H . P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure GEM GO to Pinpoint Test I . P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure GEM GO to Pinpoint Test E . P1815 Transmission 4-Wheel Drive Mode Select Short Circuit to Ground GEM GO to Pinpoint Test E . P1819 Transmission Park/Neutral Position Switch Short Circuit to Ground GEM GO to Pinpoint Test F . P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test E . P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short to Battery GEM GO to Pinpoint Test E . P1828 Transfer Case Counterclockwise Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test E . P1830 Transmission Transfer Case Counterclockwise Shift Relay Coil Short Circuit to Battery GEM GO to Pinpoint Test E . P1832 Transmission Transfer Case Differential Lockup Solenoid Circuit Failure GEM GO to Pinpoint Test G . P1834 Transmission Transfer Case Differential Lockup Solenoid Short Circuit to Battery GEM GO to Pinpoint Test G . P1865 Transmission Transfer Case Contact Plate Power Short to Ground GEM GO to Pinpoint Test E . P1866 Transmission Transfer Case System Concern - Servicing Required GEM CARRY OUT the electronic shift function test. REFER to Function Test - Electronic Shift in this section. P1867 Transmission Transfer Case Contact Plate General Circuit Failure GEM GO to Pinpoint Test E . P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure GEM GO to Pinpoint Test G . P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short to Battery GEM GO to Pinpoint Test G . - For All Other DTCs GEM GO to Section 419-10 .
Your best bet , take it to a qualified repair shop that has the diagnostic tool to trouble shoot .
Principles of Operation
Transfer Case - Electronic Shift
The four-wheel drive, electronic shift-on-the-fly feature electrically shifts the vehicle transfer case between 2WD, 4X4 HIGH, and 4X4 LOW. The system mode is selected by the operator through the mode select switch (MSS) on the instrument panel. The operator is informed which mode the system is in by two instrument cluster indicators, one for 4X4 HIGH which is 4X4, and one for 4X4 LOW which is LOW RANGE (in 4X4 LOW both the lamps are on). Shifts into 4X4 HIGH can be made at any speed. When shifting into 4X4 HIGH with the vehicle stationary, tooth blockage may occur, preventing shift completion. When the vehicle is driven above 8 km/h (5mph) the shift will complete. When shifting in or out of 4X4 LOW, the generic electronic module (GEM) requires that the vehicle speed be less than 5 km/h (3 mph), the brake pedal be applied, and the transmission in NEUTRAL (automatic transmission) or the clutch pedal be depressed (manual transmission). (The digital transmission range [TR] sensor informs the GEM when the automatic transmission is in the NEUTRAL range position.)
The gearmotor encoder assembly is mounted externally on the transfer case. It drives a rotary cam which moves the mode fork and the range fork within the transfer case between the 4X4 HIGH, 4X4 LOW, and 2WD range positions.
The GEM uses two relays to control the gearmotor encoder assembly shift between 4X4 HIGH, 4X4 LOW, and 2WD modes. The GEM controls the pulse vacuum hublock (PVH) solenoid which supplies engagement and disengagement vacuum to control the hublocks.
The GEM accomplishes shifts by interpreting inputs from:
  • mode select switch (MSS)
  • vehicle speed signal (transmitted from the ABS system)
  • gearmotor encoder plate position
  • brake pedal switch
  • digital transmission range (TR) sensor (automatic transmission)
  • clutch pedal position (CPP) switch (manual transmission)
  • ignition switch
Based on these inputs, the GEM controls the shifts into 2WD, 4X4 HIGH, or 4X4 LOW with the following outputs:
  • low to high relay (clockwise)
  • high to low relay (counterclockwise)
  • pulse vacuum hublock (PVH) solenoid
  • gearmotor encoder assembly
The electronic shift-on-the-fly (ESOF) system has a feature which allows the driver to override the vacuum operated hublocks. When the front hublocks are manually turned to the LOCK position, the hublocks are locked at all times, overriding the vacuum operated system. If the front hublocks are manually turned to the AUTO position, the hublocks can only be locked by turning the MSS to 4X4 HIGH or 4X4 LOW position.
Jun 12, 2017 | Cars & Trucks
2002 ford ranger - Where is the 4x4 actuator located
On the transfer case
The four-wheel drive electronic shift-on-the-fly feature electrically shifts the vehicle transfer case between 2WD, 4WD HIGH, and 4WD LOW. The system mode is selected by the operator through the mode select switch (MSS) on the instrument panel. The operator is informed which mode the system is in by two instrument cluster indicators: one for 4WD HIGH which appears as 4WD, and one for 4WD LOW, which appears as 4WD LOW. Shifts into 4WD HIGH can be made at any speed. When shifting into 4WD HIGH with the vehicle stationary, tooth blockage may occur preventing shift completion. When the vehicle is driven above 8 km/h (5 mph) the shift will complete. When shifting in or out of 4WD LOW, the four-wheel drive (4WD) control module requires that the vehicle speed be less than 5 km/h (3 mph), the brake pedal be applied, and the transmission be in NEUTRAL (automatic transmission) or the clutch pedal be depressed (manual transmission).
The gearmotor encoder assembly is mounted externally on the transfer case. It drives a rotary cam which moves the mode fork and range fork within the transfer case between the 4WD HIGH, 4WD LOW, and 2WD range positions.
The four-wheel drive (4WD) control module controls the gearmotor encoder assembly that shifts between 4WD HIGH, 4WD LOW, and 2WD modes.
Mar 17, 2017 | Ford Cars & Trucks
How do I repair the four wheel drive on a 1999 Ford Ranger XLT?
It depends on what is wrong , is the 4x4 light flashing ? Are you aware of the complexity of the 4x4 system ? Has a electronic control module , has the ability to set an store DTC'S - diagnostic trouble codes !
Transfer Case The four wheel drive system is an electronic shift 4X4 system that allows the operator to choose between three different modes. The operator can switch 4X4 HIGH modes at any speed. To engage or disengage 4X4 LOW the vehicle speed must be less than 5 kph (3 mph), the brake depressed, and the transmission must be in NEUTRAL.
The shift motor sense plate, an integral part of the electronic shift motor, informs the generic electronic module (GEM) of the transfer case shift motor and contact plates A, B, C and D position.
The digital transmission range (TR) sensor is located on the LH side of the transmission, and informs the GEM when the transmission is in the NEUTRAL position.
The electronic shift motor is mounted externally at the rear of the transfer case. It drives a rotary cam which moves the mode fork and range fork within the transfer case between the 4X4 HIGH, 4X4 LOW and 2WD range positions.
When the GEM verifies the completion of the transfer case shift from 2WD to 4X4 HIGH (reading the contact plate positions), the GEM will then energize both pulse vacuum hublock (PVH) solenoids (supplying ground for 45 seconds). The PVH solenoid will allow a HIGH flow of intake manifold vacuum to the "wheel end hublocks", engaging the wheel end hubs to the front differential and transfer case to achieve four wheel drive.
Here are just a few DTC'S the system can set an store in the module !
P1804 4WD High Indicator Circuit Failure GEM GO to Pinpoint Test C . P1806 4WD High Indicator Short to Battery GEM GO to Pinpoint Test C . P1808 4WD Low Indicator Circuit Failure GEM GO to Pinpoint Test C . P1810 4WD Low Indicator Short to Power GEM GO to Pinpoint Test C . P1812 4WD Mode Select Switch Circuit Failure GEM GO to Pinpoint Test A . P1815 4WD Mode Select Switch Circuit Short to Ground GEM GO to Pinpoint Test A . P1820 Transfer Case CW Shift Relay Circuit - Failure GEM GO to Pinpoint Test A . P1822 Transfer Case CW Shift Relay Coil Short to Power GEM GO to Pinpoint Test A . P1824 4WD Electric Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 4WD Low Clutch Relay Short to Power GEM GO to Pinpoint Test A . P1828 Transfer Case CCW Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test A . P1830 Transfer Case CCW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test A . P1838 Transfer Case Shift Motor Circuit Failure GEM GO to Pinpoint Test A . P1846 Transfer Case CONTACT PLATE "A" Circuit Failure GEM GO to Pinpoint Test A . Now are you sure you really want to mess with this ? You would need a factory diagnostic scan tool to check this out before you start replacing parts !
Here
May 30, 2015 | Ford Ranger Cars & Trucks
Error message repair 4wd
I guess you probably don't know what transfer case you have ?
SERVICE 4WD
Refer to
Transfer Case Description and Operation in Transfer Case - NVG 149-NP3
Transfer Case Description and Operation in Transfer Case - NVG 246-NP8
Transfer Case Description and Operation in Transfer Case - NVG 261-NP2
Transfer Case Description and Operation in Transfer Case - NVG 263-NP1
The NVG 246 EAU provides 5 modes, Auto 4WD, 4HI, 4LO, 2HI and Neutral.
The four manual mode, or range gear positions, of the NVG 261 transfer case are:
2HI - 2 wheel drive high range
4HI - 4 wheel drive high range, part-time
4LO - 4 wheel drive low range, 2.72:1 gear ratio reduction
N - Neutral, 4 wheel
The NVG 263 transfer case provides the driver with 4 manual mode/gear positions:
2HI - 2 Wheel Drive high range
4HI - 4 Wheel Drive high range
4LO - 4 Wheel Drive low range
Neutral
With the info I've given you ,you should be able too now !
There is probably a code stored somewhere !
DTC B0790 DTC B2725 DTC C0300 DTC C0305 DTC C0306 DTC C0321 DTC C0327 DTC C0359 DTC C0374 DTC C0379 DTC C0550.
Jan 31, 2015 | 2004 Chevrolet Silverado 2500
Stuck in 4x4 low switch on dash 1998
It is your 4 x 4 electronic shifter at fault. Located on your transfer case it is mostly black/brown plastic electronic switch that engages and disengages your transfer case from low, high 4 x 4 or 2 wheel drive.
Check connections for electric continuity and replace it if there is no power...
Feb 25, 2014 | 1998 Ford F150 Regular Cab
4x4 low light on car will not move
The electronic module (located behind the glove compartment) controls the operation of the transfer case in response to inputs from the electric shift motor, 4x4 mode switch, CPP switch, BPP switch, DTR sensor, throttle position output from the PCM, front and rear OSS sensors, and the VSS. Do you know what DTC'S Are ? Diagnostic trouble codes !
P1804 4WD High Indicator Circuit Failure GEM GO to Pinpoint Test C . P1806 4WD High Indicator Short to Battery GEM GO to Pinpoint Test C . P1808 4WD Low Indicator Circuit Failure GEM GO to Pinpoint Test C . P1810 4WD Low Indicator Short Circuit to Battery GEM GO to Pinpoint Test C . P1812 4WD Mode Select Circuit Failure GEM GO to Symptom Chart. P1815 4WD Mode Select Short Circuit to Ground GEM GO to Symptom Chart. P1820 Transfer Case CW Shift Relay Coil Circuit Open or Short to Ground GEM GO to Pinpoint Test B . P1822 Transfer Case CW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1824 4WD Electric Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 4WD Electric Clutch Relay Short to Battery GEM GO to Pinpoint Test A . P1828 Transfer Case CCW Shift Relay Circuit Failure GEM GO to Pinpoint Test B . P1830 Transfer Case CCW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1836 Transfer Case Front Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1837 Transfer Case Rear Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1838 Transfer Case Shift Motor Circuit Failure GEM GO to Pinpoint Test B . P1846 Transfer Case CONTACT PLATE "A" Circuit Failure GEM GO to Pinpoint Test B . P1850 Transfer Case CONTACT PLATE "B" Circuit Failure GEM GO to Pinpoint Test B .
P1854 Transfer Case CONTACT PLATE "C" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1858 Transfer Case CONTACT PLATE "D" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1866 Transfer Case Maintenance Required (GEM Only) (4-wheel drive operation can be restored by clearing the DTC and cycling the ignition.) GEM GO to Pinpoint Test B . P1867 Transfer Case Contact Plate General Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1874 Automatic Hall Effect Sensor Power Circuit Failure GEM GO to Symptom Chart. P1875 Automatic Hall Effect Sensor Power Circuit Short to Battery (GEM Only) GEM GO to Symptom Chart. P1891 Transfer Case Contact Plate Ground Return Open Circuit GEM GO to Pinpoint Test B Your best bet , take it to a qualified repair shop
Apr 04, 2017 | 2002 Ford Explorer
How do I turn 4wd on?
    • 1 Start your Dodge truck's engine.
    • 2 Turn the electronic transfer case from "2WD" to "4WD Lock" to engage the high range 4WD, if the dodge truck is equipped with an electronic transfer case; otherwise, shift the transfer case lever from "2H" to "4H." The electronic transfer case is located on the instrument panel and is marked with "2WD," "4WD Lock" and 4WD Low." The lever-equipped transfer case is located to the right of your leg and is marked with "2H," "4H" and "4L."
    • 3 Shift the transmission into "Neutral" while the vehicle is either stopped or rolling at 2 to 3 mph to begin engaging in the low range 4WD. Turn the electronic transfer case to "4WD Low," if the Dodge truck is equipped with an electronic transfer case; otherwise, shift the transfer case lever from "2H" or "4H" to "4L."
    Tips & Warnings
    • Indicator lights will come on and alert you that your vehicle is in either the high or low range of 4WD.
    • Do not engage in the low range of 4WD drive if the transmission is in gear; you must shift to "Neutral" first.
    • Many Dodge trucks allow you to shift from 2-wheel drive to the high range of 4WD at up to 55 mph--consult your truck's manual to ensure that this is possible. Do not exceed 55 mph while engaged in the high range of 4WD. Do not exceed 25 mph while engaged in the low range of 4WD.
    • Do not engage in 4WD unless you are on slipper or rocky roads.
Sep 02, 2011 | 2005 Dodge Dakota
Manual Transmission seems to be stuck in low range. Transfer case in 2wd high range, however when transmission is shifted to 5th gear still only going 25 mph at 4000pm. Clutch seems to be engaging and...
The transfer case is stuck in the low range. If manual shift try shifting from low to high several times to see if free up. If electronic, check all fuses and make sure you hear transfer case change range. Do this by shifting with key on engine off. If no change refer to qualified transmission mechanic.
Dec 25, 2009 | 1990 Ford F250
4wd high range does not lite or engage
I had the same problem with my 98 sierra 4x4. Turned out that the electrical activator on the transfer case was not working. It will still go into 4 low but not 4 high. Replace the electrical switch on the transfer case and it should work again.
Dec 29, 2008 | 1998 GMC Jimmy
Motorola GP88 Two Way Radio. Logo
27 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
