Question about Zebra S4M Thermal Label Printer
Network issues - zebra s4m
Trying to network the S4M Label printer, We hit the button on the back of the printer with a paper clip, hold it in, and turn the printer on. The green light flashes for a while, then flashes amber, then just flashes red. How do we get it to stay on a continuos green light?
  • 3 Answers
SOURCE: Zebra S4M prints one label then goes to flashing pause light.
most likely it is a printer driver issue. There's 2 drivers, one for 200dpi and one for 300dpi. Use the one for 200dpi. It could also be the label setting is incorrect. Try running a calibration.
Posted on Jan 27, 2009
  • 9 Answers
SOURCE: zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
  • 3 Answers
SOURCE: How do I identify my SM4??
The configuration code you posted uses ZPL II or XML
Have a good one!
Brian Wallace
Peak Technologies
877-863-2522 x 6807
Posted on Jul 10, 2009
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
SOURCE: Zebra S4M (S4M00)models keeps losing config
Your solution provided absolutely no help. All I needed was a manual for the printer so I could order a part. Sending me to a site so I could order supplies for the printer is not my idea of providing a quality solutions nor is offering me a "Premium Assistance Plan" of any value either. I would suggest that if you are not going to try and resolve the issue on the first go around that you simply tell the person you can't help them.
Posted on Jan 12, 2010
Restore defaults
hold pause+feed buttons while turning on the printer. release after 10secs.
Oct 01, 2013 | Zebra S4M Thermal Label Printer
Hi WITH THE ZEBRA DESIGNER I SETUP MY S4M FOR A 4X 6 INCH LONG LABEL THERMAL DIRECT BUT PRINTING STARTS ON THE MIDDLE OF THE LABEL AND GOES OVER THE NEXT LABEL TRIED TO CALIBRATE VIA SOFTWARE BUT WAS...
This will make your printer feed out 2-3 labels each time it is turned on or the head is closed to determine the label length.
SET/UP EXIT
Hit the "+" quite a few times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to enter the password (1234)
Hit SELECT - you should see a small - and + button on the screen on either side of NO MOTION (if not, repeat previous steps)
Hit the + sign until you get to CALIBRATION
Hit SELECT to exit MEDIA POWERUP
Hit the + button to go to the next item HEAD CLOSE
Hit SET/UP EXIT (twice) to save changes (permanently)
Open and close the printhead to check to see if it worked!!!
Jun 08, 2011 | Zebra S4M Thermal Label Printer
Zebra S4M printer Alert Message: Ribbon out I'm using a thermal paper. There is no print method mode.
In the software printer driver- set it to direct thermal or no ribbon. It will override the printer setting.
Dec 09, 2010 | Zebra S4M Thermal Label Printer
How do i change the media power calibration on a Zebra S4M printer
Go to www.zebra.com and download the S4M pdf user manual. It guides you how to change configuration.
Oct 27, 2010 | Zebra S4M Thermal Label Printer
How do I load/install the roller ribbon for the zebra stripe S4m printer?
If you GOOGLE "zebra s4m manual" you find a number of manuals you can download as a PDF and the instructions for loading the paper is in that manual.
Jul 12, 2010 | Zebra Stripe S400 Label Printer
We relocated our Zebra S4M to the new area and it
Have you tried resetting the printserver? I am assuming this is a networked printer when you say the red light on the back. There is a little button on the printserver. Turn printer off, and while pressing that little button in with a paperclip, turn the printer on and continue holding in the button until the light is a solid green. Could take a minute or two depending on the network.
Oct 06, 2009 | Zebra S4M Thermal Label Printer
try looking at the bottom of the printer, it should have the detailed model in there
Jun 22, 2009 | Zebra S4M Thermal Label Printer
My S4M printer's light flashes, and it spews out label paper
You need to check to make sure media and ribbon (if used) are installed correctly. Follow the path on the inside of the door. The sensor is positioned in a place that the media and ribbon can be loaded in the same spot, causing it to not see one or the other.
Jun 17, 2009 | Zebra S4M Thermal Label Printer
S4m is not printing
zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
Dec 30, 2008 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
217 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
