Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
How to fix lens error on sx130 - Canon PowerShot SD500 / IXUS 700 Digital Camera
  • Canon Master
  • 4,738 Answers
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
And here's a video summary of the steps:
Posted on Feb 21, 2012
How to remove lens powershot sx 130 ?
This is a fixed lens camera, you cannot change lenses. If there is some problem with the camera's lens the best advice I can give you is to take it to a camera shop for repair.
Jul 12, 2014 | Canon PowerShot SX130 IS Digital Camera
Lens does not open
My friend was on a site where many people with thw same problem said their warranty was expired and they were gently hitting their camera from various sides on the desk, but my friend hadnt tried it because her she still has warranty.
Mar 29, 2013 | Canon PowerShot SX130 IS Digital Camera
Memory card stuck in powershot sx130 iscamera
To get the card out. push it down and you'll hear a click and then it will pop up. Check the slide switch on the card to see if it's locked which "might" be causing the error.
Dec 16, 2011 | Canon PowerShot SX130 IS Digital Camera
I have a Canon Powershot SX130 IS and there is dirt behind the first piece of glass in the lens , anyway to clean it?
You shouldn't try to clean this yourself, find a camera shop that does repair or contact Canon, they will direct you to one in your area.
But before anything you better make sure the dust has any impact on the pictures.
May 07, 2011 | Canon PowerShot SX130 IS Digital Camera
Lens error, restart camera
Checkout this tip about digital camera error messages
Lens Error fix for Digital Camera
heatman101
May 04, 2011 | Canon PowerShot SX130 IS Digital Camera
Hello sir, i don't know what exactly happened to my canon sx130 IS but buttons are not working and the lens is automatically zoomed out permanently....what to do please give me some suggestion
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Feb 26, 2011 | Canon PowerShot SX130 IS Digital Camera
My Cannon SX130 Lens is not closing properly or opens properly it got stuck in half way
this happens due to some sand particles getting stuck in lens assembly. give a small **** to the camera so that it gets released.
if not take it to service center in your area and get it repaired.
Jan 15, 2011 | Canon PowerShot SX130 IS Digital Camera
I accidently droped my camera From the height of my knee .. Now the len's will not come out
this means the lens assembly is damaged. this is not a simple fix to do at home. Please take it to authorized service center
Dec 28, 2010 | Canon PowerShot SX130 IS Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
129 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
