Laptop powers on than shuts down - Computers & Internet
  • 1,214 Answers
Michael
I am afraid that English my fails me now. Is the power on when you mean that you have shut the laptop down. If that is the case it helps to close every program down before shutting down.
good luck
Kolbrun
Posted on Feb 16, 2012
Laptop will not shutdown
Remove the battery and unplug it from the wall. Try holding down the power button for about 8 seconds it should shut down. Just a suggestion! When you shut down your laptop make sure that your shutting down properly at the start button select shut down. If all else fails and this does not work.
You may want to have the power button checked out or the board. Or clean files out and start up programs add-ware or spy-ware may be preventing you from shutting down as well. This is also a common issue that causes very slow shutdowns on any computer system packed up junk having to close out. John
May 11, 2012 | Dell Latitude E5500 Laptop
MY asus laptop not shut down, it's only shut down click hybenate mode why?
go to energy settings and find out the settings and change the behavior for the power button.
Apr 05, 2012 | ASUS Computers & Internet
I have a Gateway Solo Pro 9300 laptop. Whenever I shut it down, the power light turns orange, and the backlight is still lit. Other than that, the hard drive and fans turn off. What does this mean. How can...
That means the computer is in 'Sleep' mode. To completely shut down the laptop, you can press the power button once and it will do a normal shut down.
May 08, 2011 | Computers & Internet
I press the power off button and it doesn't power off
You should never power down by pressing the power button unless your system is deadlocked and won't respond to any other actions. Powering off in this fashion can cause you to lose data, corrupt files, and improperly shut down Windows.
Nonetheless, if you are in need of shutting down the laptop in this fashion you must hold the power button instead of only pressing it. You'll find this in the power settings of the device. Honestly, the power button may even be set to do nothing, which is possible.
To properly shut down your new Pavilion laptop, which should be running Windows 7, follow this process: Click Start > Shut Down
Start is now simply a circular Windows icon in the bottom left corner of the screen and shut down has an arrow pointing down next to it. Click the words shut down instead of the arrow which will bring up other power save options.
Oct 17, 2010 | HP Pavilion dv7-1245dx Notebook
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Power led remains lit at all times with battery or power plugged in. Fans turn on when powered on but no system response. Was able to get system to power on by compressing laptop above and below DVD with a...
ok you have laptop. Look for a key called "Fn" it should be around the ctrl or alt key on your keyboard. Try pressing that. After trying to turn it on and it wont. press the Fn key. The last time you were able to use the laptop how did you shut it down? Did you tell it by going threw the menu when logged on. Or just pressed the button? Or did you tell it to shut down then you closed the screen/lid before it actually shut down? Laptops will go into stand by after you tell it to shut down if you dont wait til it shuts down, before shutting the lid. ALso depending on the laptop company you have Trying to figure out which one it is. They have program installed with your system. And depending on how it's set up, will greatly effect how or even IF your laptop will shut down right.
Oct 10, 2009 | Gateway M675 Notebook
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Hi, my satellite pro laptop is powered up. I can not shut it off.
If the laptop does not shut down if you go to Shut Down, you can try pressing the power button and see if it shuts down, if not, hold the power button down for 5 seconds and it will power off.
Jun 24, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
