Question about Zanussi Washing Machines
Zwf12070w1 replaced belt now very noisy on fast spin
The machine stopped spinning. on opening the back belt saw that belt had come off. replaced the belt but then when on spin cycle it now makes a loud grinding/whining sound. tried tightening the mounting for the drive pulley ( which i'd mistakenly loosened whilst refitting belt). improved a little but problem still remains. also tried pressing start button and button to the left (as stated on another post) so lights were scrolling and then move the dial around slowly clockwise etc. what else do i need to do? any advice would be greatly appreciated jon.
  • Jon Hopkins Feb 16, 2012
    How do I tighten the belt tension as it could be that?
  • 64 Answers
Hi. Your mistake with not tentioning the belt when you switched probably caused your main bearing to shot. Check if your motor is centred with the drum
Posted on Apr 27, 2017
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 13 Answers
SOURCE: Drum noisy when spinning
main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
Posted on Feb 02, 2007
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
If this sound starts slow and gets faster till its helicopter sounding you probly have a verry worn spot on the drive belt when that spot goes around the pully it will thump the faster ti spins the more frequent the sound If you tilt the washer back you should be able to see the belt to examine it if this the problem
replace the belt
Hope this helps
please leave feedback
Nov 27, 2009 | Maytag Legacy Series Top Load Washer
Will not spin fast, when it spins you can rase lidmby pass door switch and stop itfrom spinning
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Oct 22, 2008 | Roper RAS6233KQ Top Load Washer
    Noisy machine AEG Lavamat 35600 Tumble Dryer
    moter 1st i would say thx nick
    Feb 10, 2008 | Dryers
    There was a rubber smell, now washer won't spin.
    It is possible that the bearings supporting the drum have seized
    Was the machine noisy before it stopped?
    If there is tension on the belts and the drum is locked then the motor will spin and burn the belts.
    Aug 18, 2009 | GE WBSE3120B Top Load Washer
    Dryer guide wheel was noisy and I opened the dryer up and found the wheel and stud badly scored. Fixed that and put machine back together and now the motor is very noisy and the machine shuts off...
    you need to check the blower fan. the motor has a "D" shaped shaft. over time the blower wears, the motor will spin but the blower does not. the air flow stops and the drier over heats. replace the blower and it should be fine.
    Nov 08, 2008 | Dryers
    Wm noisy
    drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
    Sep 25, 2007 | LG WD-16110FD Front Load Washer
    Noisy Washer
    may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
    Jul 25, 2007 | Maytag Performa PAV2200
    WMA62 aborts all programs after 2 initial spins
    if this washer is trying to spin when you put it on a wash cycle at the beginning and it trys a fast spin then you have a timer fault m8 if on the other hand its working fine through the wash cycle and not doing the spin properly then it has to be your belt isnt tight enough if your cab=rbon brushs are fine m8
    Dec 09, 2006 | Hotpoint WMA64 Front Load Washer
    Washing Machines Logo
    50 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
