Question about Tablets & eReaders
Cannot turn on my my Arnova 7c G2 tablet
The battery ran out so I recharged and attempted to switch on. the "Arvona" screen comes up for a few seconds and then it trys to start showing "android" screen but this just loops. I've tried fully charging, resetting with and without the sim and memory card but nothing works. It was fine before the battery flattened. When you put it on charge, the bottom four buttons alluminate but nothing more. The only way to turn this off or to stop the looping boot-up is to push the reset in on the back with the power un-plugged. Help!
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
  • 5 Answers
SOURCE: my literati wont turn on
Hm. Not sure how much help I'll be, but I'll give it a shot.
- Make sure the device is charged for at least 6 hours if this is its first use. If it isn't, charge it for several hours anyway and try it again. Make sure the charger is plugged all the way into the outlet and all the way into the device (mine sticks out about an eighth of an inch, yours might too). - Call customer service at 866-204-4714 and describe the issue. I had something a little like this issue (I was stuck at "Literati" screen) and they said to drain the battery and recharge it fully to see if it made any difference, and that if it didn't work they'll be sending along a package to ship it back to them for a replacement. If nothing works, ship it back to them for a replacement.
Posted on Feb 15, 2011
SOURCE: After i put in the
back up arnova and reflash the firmware. that solved it for me. still the wireless is fickle. sometimes, I tell it to forget network and then refind it. and sometimes it doesn't and I have to manually add it. My hunch is this model may have wireless issues.
Posted on Aug 06, 2011
TechyDrood
  • 2072 Answers
SOURCE: How do I download kindle from amazon on my arnova
Go to the Android Market and search Kindle and install
Posted on Oct 16, 2011
TechyDrood
  • 2072 Answers
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
My tablet does not charge
If the power supply is OK,then clean inlet of tab and jack of supply. Make sure the tab is powered off and the battery is not connected.
Oct 09, 2014 | ARNOVA 8 G2 Wireless PC Tablet - 8 GB USB...
Arnova 7b G2 touch screen doesnt work
i have same problem here and i didn't find any solution yet still search and wait ..
Feb 24, 2013 | ARNOVA 7b G2 tablet - 4 GB ARNOVA
White screen won't turn off or close
Try pressing the power button and tapping the screen at the same time. Otherwise wait for battery to die and it should be ok when recharged.
Dec 26, 2012 | Archos ARNOVA 10 Android Tablet
How to factory reset arnova 10 g2
cannot download androids market, keeps failing
Jun 28, 2012 | Archos ARNOVA 10 Android Tablet
Archos 10g2 wont load up
Just flash the default firmware from the manufacturer:
http://arnovatech.com/support/firmware/2/arnova10g2/111010/update.img
http://arnovatech.com/support/updates.html?country=us&lang=en&p=2
Flashing a firmware means installing it in the device protected flash memory, more explanations here: http://www.addictivetips.com/mobile/what-is-meant-by-firmware-stock-custom-roms-and-flashing-guide/
The firmware flashing procedure for your device is detailed on Arnova web site:
http://arnovatech.com/support/firmware.html?country=us&lang=en&g=2
Jun 25, 2012 | ARNOVA 10 G2 8 GB PC Tablet with WiFi...
My arnova 10 G2 will not connect to wifi network do i need a micro simcard
Arnova 10 supports b/g wireless network. Try to setup your router not to establish n wireless network.
Feb 05, 2012 | Archos ARNOVA 10 Android Tablet
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
Tablets & eReaders Logo
142 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
