If my battery for my computer is shot will my little backup battery need to be replaced as well
My battery has been no good for a while in time would that ruin my little backup battery ya know wear it down to nothing!!
  • 32,281 Answers
The BIOS battery may not need changing provided the Date and Time setting does not change each time you boot up. If the laptop is more than 3 years old then it you can elect to replace the BIOS battery.
Posted on Feb 17, 2012
How do I fix a
If you have had this a long time it could be shot. Basically it is just a battery that can only be recharged so many times before it is bad. Most likely you will need to replace the unit.
Jun 14, 2016 | APC Back-UPS® XS 900 (BX900R) UPS System
Hi, I am Indra,, I have a LG Studioworks 563A monitor,, always time is ok,, but evening time is some disturb me,, this monitor evening time voltage capability fault with UPS,, when i start my computer, UPS...
Not sure I fully understand the question but I'll give it a shot. If you mean that your UPS backup shows a fault.. more then likely the problem is with your UPS backup and not your monitor.. (unless your monitor is shorting out or has to much feedback to the power)
A few things that can cause this is a BAD UPS battery or a underrated UPS backup for devices. Based on the information you gave this monitor is a OLD CRT type monitor which uses quite a bit of power. I would first try the UPS backup with other devices to see if the same problem happens just like a computer or any other electrical device with out the LG connected. If the same problem occurs replace the battery and/or UPS backup, if it doesn't ... then you might have to just replace the monitor as it might be shorting out. With out proper test equipment a definite answer might be hard to come by.
Nov 05, 2013 | Computers & Internet
Trying to replace the little round lithium backup battery but it is held with clips. How do I remove the battery
Press the clip with a sharp point on the inside edge towards the outside edge and the battery will pop up. You may need to lever the battery up at the same time.
Feb 11, 2012 | Toshiba Satellite A105 Notebook
Change the backup battery in MC9060
Hello mis1539. I think I can help you here. First: are you sure the backup battery is defunct? Bear in mind that the backup battery takes about 15 hours to fully charge and will discharge if the main battery or power source is disconnected or goes completely dead for anywhere from 30 minutes to a few hours. If the backup battery discharges, the process starts all over and the backup battery will need to be charged for 15 hours again. If you think the backup battery may have discharged at some point, it could be that it never full re-charged so it will discharge and lose your settings (cache/flash memory) almost instantly. It is worth mentioning that about 95% of my clients that have this problem have fixed it by simply making sure that the unit is in it's cradle, with the battery in and charging overnight to fully recharge the backup. Again, I really would implore you to give this a shot before resorting to cracking open the unit and getting to the backup battery (which is no fun task, I assure you). If this doesn't work for you, please let me know and I can help you further. I hope this solves your problem. Good luck!
Sep 23, 2009 | Symbol MC9090 Mobile Computer Portable...
I have several calculators that won't work from just not turning on to one of the buttons is broken, where can i send them to be fixed?
For the ones that won't turn on, it may be that your backup battery needs to be replaced. The backup battery is above the 4AAA batteries behind a little door with a screw. Before you go buy a new backup battery, try leaving the backup battery and the AAA batteries for about i hours and then put them back in. It could be that the calculator just needs to be reset. Good luck.
Aug 05, 2009 | Texas Instruments TI-83 Plus Calculator
Battery test failed
1. Replace the batteries because they NEED to be replaced. It is not wise to ignore alarms.
2. Remove the battery backups. Without good batteries they are useless so why waste your time silencing alarms. Just make sure that the computers are plugged into a surge-protected outlet and you save your work frequently when there is bad weather.
FYI: Retail UPS batteries are only good for 2-3 years and high-end commercial batteries are only good for 3-5 years.
I hope this helps.
Jul 20, 2009 | Powerware 9120 UPS System
Alarm mode question
sounds like battery failed, check the connections and clean them, then try it again. see if the battery is ok, check voltage, and shake the battery, if you hear little objects rattle inside, it is bad. i hope this is helpful,good luck,glen also consider the unit could be shot.
Feb 11, 2009 | Powerware Series 9 9150 UPS System
Cmos settings
CMOS is a memory chip on your computer that stores BIOS information as well as system clock. It powered by a 3V backup battery. If your computer is more then 3 years old it is possible that the backup battery on your PC needs to be replaced. Replace your battery then go to BIOS setup and adjust your date and time. But it is also possible that the clock is a bit off, so first your can just try to adjust your clock without replacement of the battery. You can also do it inside the windows from control panel. Be sure you have a correct time zone.
Good Luck!
Jun 08, 2008 | Intel Motherboard
Black screen
If one of these solutions doesnt work you will most likely need to purchase a new calculator.
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 12, 2008 | Texas Instruments TI-83 Plus Calculator
Date time setting does not program
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Feb 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
