Question about MSI K8N Neo4-F Motherboard
MSI mother borad came home with wires un hook
I have pic of the whole thing its MSI k8t Neo 2 ms-6702 VER 1 the wires r power sw h.d.d led , reset sw, +p LED, -p LED, 2 ground, 2-d, 2vcc, 2+d, 1ground, 1+d, 1vcc, 1-d
  • Susan
    Susan May 11, 2010
    Hi, Do you have the manual that came with it?
No i dont
Posted on Oct 26, 2008
    Scholar:
  • 40 Answers
In your original subject line you list your motherboard as "MSI K8N Neo4-F Motherboard"
In your original message under that title you list your motherboard as
MSI k8t Neo 2"
Go to this link
http://global.msi.com.tw/index.php?func=prodarchive&maincat_no=1
Double check and get your CORRECT motherboard number off the board itself.
Find it in the list and click on it. You will see options for drivers and manuals.
The manuals will tell you how to hook up your board.
These downloads are free.
if by chance this link doesnt work by the time you get this.
Google MSI + motherboards and you will see the maker of your motherboard.
Go there, select mainboards from the list of products and you will get the list I have recommended. Again, look for the correct motherboard number and click on it to get drivers and manuals.
Thank you and good luck. *s*
Posted on Oct 27, 2008
Msi-k8t-neo motherboard ms-6702 user manual
Thank you for the connection.Please visit the following website and download the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Regards,Avishek
Sep 28, 2011 | MSI K8T Neo-FSR Motherboard
I have a PC with motherboard MSI MS 6702, I cant find the Ethernet controller driver for it ! Thanks for help
I got drivers for you. The first link is for win vista32 and vista64 drivers.
2nd link is for XP32, win 2000, win 95,98, NT and all other pre vista versions.
If you need drivers for other OS, PM me.
Link1: http://www.ziddu.com/download/15101799/Realtek_Gigabit_NIC_Vista.zip.html Link2: http://www.ziddu.com/download/15101800/Realtek_Gigabit_LAN_MB.zip.html
May 24, 2011 | Computers & Internet
Hola buenas tardes queria pedirles una ayuda con mi pc, porque formatie mi pc y no tengo lo drivers, los driver de la placa mdre MSI k8t ne fsr ( Ms 6702) , desde ya agradeceria su ayuda.
Do the updates from Microsoft some times they are there if not go to the maker of *********** board and look under they're support they should have them.
Feb 03, 2011 | MSI K8T Neo-FSR Motherboard
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
Intel motherboard how to find power switch,led,reset,hdd switch,led
It is silkscreened on the moterboard at the bank of pins for the switches and lights. it is usuall abreviated as PWR SW, RST SW, HD LED, SPKR, PWR LED, ...If it is not silkscreened then look at the manual on the manufactures website. they will have a photo of the MB with it illistrated. go to
http://www.retrevo.com/support/MSI-K8T-Neo-FSR-manual/id/8353ci976/t/2/
Apr 22, 2010 | MSI K8T Neo-FSR Motherboard
Looking to plug in my main switch and need help with finding the right port(s)...only see one color coded set of pins available....
Open the link provided below by MSI;
Download and install Adobe reader to view manual.
Adobe Free; http://www.adobe.com/products/reader/
Manual for K8T Neo-FSR;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo-FSR
Download the maual if needed. Open to page 2-20.
Use the manual to connect you're case wires to the motherboard. JFP1 provides power to Reset Switch, HDD, Power on switch and Power LED. Use JFP2 - connect internal speaker. (Bios uses this for POST).
Power On Self Test. If you use Adobe you can zoom in on pg. 2-20 which will help you connect each set of wires to their matching MB pins.
Cheers'
Mike
Feb 18, 2010 | MSI K8T Neo-FSR Motherboard
Msi motherboard for model k8t neo ms 6702
Its the model numbers that vary the most when looking for the manual. Click on the link below to open MSI download site;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+NEO&table=download
While on MSI's site I searched for MS-6702 and left out the term, "K8T NEO". MSI provided the another link; http://www.msi.com/index.php?func=searchresult&keywords=MS-6702&table=download
The model numbers K8T Neo-FSR and FIS2R, use the same manual.
See link; http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565
K8T Neo2-F and FIR use the same manual.
From the pic included, Connect everything to JFP1. Connect the speaker to JFP2.
b972b2a.jpg Wire colors do vary from case to case. Normally solid colors like red, green, blue and dark blue are used as positive. White and black are negative. Each jumper pair will share a common color. That common color is negative except when hooking up the speaker wire. Black is used for negative.
Cheers!
Mike
Oct 24, 2009 | Computers & Internet
SATA Drive on MSI K8T Neo MS-6702 Ver 1.0
I believe when first installing windows it asks you to press F2 if you want to load sata drivers
Have them handy and follow instructions
Sep 19, 2008 | MSI K8T Neo-FSR Motherboard
No display
Your monitor's signal cable is loose.Tighten the screws of the cable....
Oct 12, 2007 | E-Machines T2615 PC Desktop
MSI K8N Neo4-F Motherboard Logo
722 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
