Question about Dell 3110cn Laser Printer
Data wait message when trying to print - Dell 3110cn Laser Printer
2 Suggested Answers
  • 197 Answers
SOURCE: when I try printing I am getting a data wait message then it prints pages and pages of rubbish
did you get a cd with all the drivers on it if so uninstall the printer and reinstall the drivers with the cd , if this dose not work then go to dell and go to printers and put in the brand it is and it should show up as your printer, scroll down and it should give you some options for some drivers try to pick the one that is close to your printer , and if this doesnt work then i think that you will have to get a new printer
if you are still haveing problems then let me know
thank you and good luck
Posted on Apr 08, 2012
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Jul 31, 2012 | Lexmark E250dn Laser Printer
Canon imagerunner 3225 will not print
Hi Shailana.
Maybe Toner / Ink is depleted?
Any messages / flashing lights on printer interface?
Regards,
Clive.
Oct 28, 2017 | Canon imageRUNNER 3225 Black and White...
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
Print off text messages.
You might try sending your messages to a fax # maybe you can copy them that way.
Jan 26, 2012 | Cell Phones
Hi, when I'm trying to to use the brother firmware update tool, an error message appears reading "your computer is processing print data. please wait until the print job is competed... There is no...
This is a normal message. All it is is the software has not been written to say something like. "New firmware is being sent to the printer" instead they have used the words you are getting. As you have not waited long enough for it to complete you may well have ruined the firmware and the main board. If however the machine is still working then by all means try the update again and wait for it to finish. I wonder why you are doing the firmware update as it is for a machine that is suffering problems. If the machine is working ok then DO NOT update the firmware.
Good luck.
Sep 17, 2011 | Office Equipment & Supplies
PRINTER SHOWING THE MESSAGE TO AVOID DAMAGE USE THE ON BUTTON TO SHUT DOWN DO NOT USE POWER STRIP OR WALL SWITCH TO SHUT DOWN
Your question is kind of confusing. From what I get is that your printer is saying to not shut it down by unplugging it or breaker switch? If that's the case simply hold the power button till it shuts down (if it doesn't shut off after 5 seconds release and it should shut down).
If the message is saying do not shut it down at all, try and wait it out. It could be loading drivers or saving data etc etc.
Another problem it that you could have print jobs waiting and shutting down could corrupt data. Try and look at the bottom right of your computer screen and find a printer icon. From there you should be able to right click and disable pending print jobs etc etc.
Hope This helps!
Feb 19, 2011 | Office Equipment & Supplies
Getting a printer error message, says remove rear accesss cover, clear allpaper, attach ocver, press ok to continue...i have done that, still getting message, no pare jammed, have also turned it off and...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 01, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Printer is asking to replace black catridge when u do so message still says replace black catridge even if u take all the colors out still says the same message
Jan 25, 2011 | Brother DCP-330C All-In-One InkJet Printer
0xc18a0401 appears on the screen after start up of the printer When trying to copie : same fault. Can you give me some advise.
Try resetting the printer. With the unit on, unplug the data cable (USB) from the back of the printer. (At times, unplugging the data cable from the computer helps). Then remove all of the ink cartridges and wait for the message "Insert Ink Cartridges" to appear. At this point, unplug the power cord from the back of the printer. Wait 60 seconds (or longer) then plug the power cord back in. Power on the printer if it doesn't come back on. Reinstall the ink cartridges when the unit prompts you to do so. Close the cover. Print a calibration page if you get a prompt to do so. (Do the complete calibration including scanning the calibration page.) Finally plug in the data cable (to both the printer and the computer if you completely disconnected it). .
Try printing again.
If the error persists, the unit needs service from HP. You will need to decide if the cost is worthwhile if the printer is out of warranty.
I hope this helps.
Dec 02, 2010 | HP Photosmart 3210 Printer
Pixma MP780 Series All-in-0ne Printer
is it print test print direct without plug in computer. replace also data cable of printer .
Mar 01, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Dell 3110cn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
