Question about Boating
Shaft removal from 200 yahama - Boating
    Problem Solver:
  • 7 Answers
There will be a big castellated ring nut, punch back the locking tab/sIf you don't have the special tool, you can use a punch, Just be careful you don't hit the casing, and replace the castellated nut with a new one?The prop shaft bearing carrier will the pull out, not quite that easy but it will pull out! This will give you direct access to the drive shaft nut so you can remove the drive shaft. You need a work shop manual!
Posted on Feb 19, 2012
2006 yamaha vstar 650 had a bad vibration something popped in rear will not go into gear drive shaft steadily turning
Hi, Peggy you may have broken a U- Joint in the drive shaft for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Middle Drive Shaft Star 1100 Wiki Knowledge Base
Vstar 2004 650 Runs but wont go forward
1998 Yahama star 650 Drive Shaft
http://s.productreview.com.au/products/manuals/32141_563ae9ef16ab5.pdf free service manual
May 27, 2016 | Yamaha Motorcycles
Drive shaft loose XVS 650 Dragstar
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha Vstar 650 drive shaft failure
Yamaha XVS650 Service Manual
OEM parts for Yamaha
YAMAHA XVS650 Owner Manual
Mar 21, 2014 | 2002 Yamaha XVS 650 Dragstar Classic
How do i remove the driven yoke on a 2002 v-star classic
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha Star 650 Rear Wheel Removal
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Mar 13, 2013 | 2004 Yamaha V Star Classic
Yahama 9.9 outboard how to remove large shaft for lower unit yr 1994
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Aug 08, 2012 | Cars & Trucks
I need to replace a tire on back of a 2003 yahama v star and its shaft driven so how do i go about it
This should help you a fair bit, it's not that big a job.
Instructions below found at:
http://motorcycle.justanswer.com/questions/1ayag-remove-rear-wheel
In addition to the obvious of elevating the back of the motorcycle to get the weight off the rear tire, you need to unbolt the final drive from the swing arm and remove the final drive and rear wheel as an assembly. The drive shaft will come out with the final drive, not a problem.
Once you get the assembly off the bike, you can remove the axle then separate the final drive from the rear wheel and do what you needed to do.
When you go to re-install the drive shaft, you have to align the splines. Sometimes it is easier to put the bike in gear so the female splines on the intermediate shaft don't turn as you rotate the rear wheel to insert the drive shaft.
When you go to put it back together, just tighten the bolts that hold the final drive to the swing arm evenly in a crossing pattern until tight.
As an aside note, while you have it off, make sure you grease the splines on the end of the drive shaft and the splines for the rear wheel before putting it back together
All the best, plainnash
Jun 09, 2011 | Yamaha V Star 1100 Classic Motorcycles
How much oil does a 2005 Yahama TW hold?
Without oil filter element removal 1.0 L (1.06 US quart)
With oil filter element removal 1.10 L (1.16 US quart)
Oct 03, 2010 | 2005 Yamaha TW 200
Middle gear shaft nut broke off can middle gears be removed without busting and removing engine2003 v star 1100. this is where the drive shaft connects
Hi, Mdiefenbach "ABSOLUTELY" for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Mar 22, 2010 | 2003 Yamaha V Star 1100 Classic
Removal of motorcycle rear tire/shaft driven
The final drive assembly has to be unbolted from the swingarm and it is removed with the rear wheel. Once the assembly is off the bike, the axle can be removed and the final drive separated from the wheel.
Jul 16, 2009 | 2005 Yamaha V Star 1100 Classic
How to remove rear wheel on a 1981 650xj yahama
hi m8,,undo the wheel spindle nut ,,tap the spindle out of the swing arm,and untill the spindle is out of the wheel,, then undo the rear brake at the wheel ,and u should be able to pull the wheel off the shaft drive,, leave the shaft drive on the bike m8,, just riggle the wheel off, it should drop out with out removing the shaft as well,, or u will have shaft oil spewing out over the floor,,,,then when u put the wheel back in,, u should be able to plop the wheel back in to the shaft easy enuff,,,
Mar 21, 2009 | 1981 Yamaha XJ 650
Boating Logo
37 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
