Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool front loader
I have a whrilpool front loader it has gotta f1 code what can I do to fix the problem
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 21, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    Whrilpool front load washer keeps flashing f 02, how do i fix this
    SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
    Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
    Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
    Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    My front loading washing machine started and then displayed f1, now it will not start at all and when I pushed the start button it beeps three times and does nothing.
    The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Thank you !!
    Aug 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F-02 error code on whirlpool front loader duet
    http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
    May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F1 code whirlpool
    whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whrilpool duet front loader washer flashes f2
    HI. this code represents a Long Drain issue.
    If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
    Press PAUSE/CANCEL twice to clear the display.
    NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
    Potential Causes
    • Check the drain hose and make sure it is not plugged or kinked
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects
    • If the above does not correct the problem replace the pump..
    Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    51 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
