Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer water doesn't drain out while spinning, codes I get is OB, O1 and L7
  • woodsnwoods Oct 27, 2008
    I have the same washer and almost the same problem. I only have one code "ob" come up.
  • fcanon Oct 30, 2008
    the water will not drain from my washer and now washer will not spin nor wash...
I have the same problem they told me that probably something was stuck in the pipes and i check them and they were just fine a little debris but nothing serious then a technician told me that it was the water pump so im about to replace it i let you know if it work
Posted on Nov 05, 2008
    Sergeant:
    Champion:
  • 324 Answers
Code ob is a off balance load.could be the universal joint is bad.
Part # 285927
Posted on Nov 03, 2008
My calypso washer keeps stoppng and it comes up with the code LD, OB, 5L i'm not sure how to fix it.
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
SL = Suds Lock
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer/main controller/timer failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer had an error code of OB. Is this Off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
May 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
I have a calypso washer, it makes a grinding sound and the water will not drain out. it also keep boping up ob code, i have trye to balance it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%@
Dec 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Leaking water on spin and not draining. getting ob code
Dec 12, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer OB CODE after install of nee PUMP/MOTOR combo.
Jun 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal De
