Question about LG Televison & Video
Can't tune 19lg3100 to Digital channels
    President:
  • LG Master
  • 1,779 Answers
If your using rabbit ears or outside antenna, make sure the tuner is set to AIR (via) the menu. Then Auto Program.
Posted on Feb 17, 2012
5 Suggested Answers
SOURCE: Hi, I accidentally tuned my goodmans
There should be a button marked source,press this then scrol to the one marked dtv,hope this helps.
Posted on May 12, 2011
ltfrc
  • 227 Answers
SOURCE: problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Posted on Mar 23, 2009
Kensolutions
  • 455 Answers
SOURCE: Hi. I have a Sony
This solution is designed to assist when all or some of the available channels are not stored or are missing when trying to change the channels directly on a TV. If using a cable set top box or satellite receiver, refer to the manual supplied with the device or contact the manufacturer for tuning those channels.
Verify that the cable or antenna wire is connected to the VHF/UHF input on the television.
The use of signal splitters can diminish reception. If signal splitters are being used to send the signal to multiple televisions throughout the home, then the signal strength may be too degraded to provide good enough reception and a blue screen or snowy picture may be displayed.
If a VCR is connected to the television, turn off the VCR.
If using an antenna, try adjusting its position.
The type of antenna being used and how far away a particular station is helps determine what type of reception you will receive; the reception of certain stations may be better than others. To determine which stations are available in your area and to find out the recommended type of antenna to use, visit the http://www.antennaweb.org Web site.
Televisions with digital tuners require a signal strength of at least 25% before a digital broadcast will be displayed on the screen. A low digital broadcast signal may also cause intermittent loss in signal. The Federal Communications Committee has set up a support center for customers who are experiencing transmission issues with specific DTV stations. In these cases, call 1-888-Call-FCC (225-5322) for further assistance.
Verify the television tuner is set for the correct signal type.
Set the tuner to Antenna or Cable:Off for receiving over-the-air broadcasts.
Set the tuner to Cable or Cable: On when receiving cable TV broadcasts.
Auto Program the television.
If the problem persists, manually program the channel into the television.
Not all Sony TVs have the capability to manually add digital channels to the memory. If some digital channels are not being stored, but can be viewed by entering them directly with the remote then the signal for that channel would require further improvement.
If the issue is still not resolved, test the antenna or cable by connecting it to a different television.
If the issue is present with a different television, the antenna or cable service is faulty.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Thanks for contacting FixYa.
Posted on Aug 07, 2011
SOURCE: Sony Bravia Digital TV won't
These numbers are the LCN (Logical Channel Number) assigned by the broadcasters. It will only be at 350 if it is the same channel from a different transmitter. You need to know the 'channel' of the frequency to manually tune it in. You are talking about the program number not the channel (frequency), a common mistake. i.e ABC in Sydney is transmitted on CH12 (226.5Mhz) and the LCN's for each program are 2,21,22,23,24,201 & 201. If your antenna also picks up the signals from the Kings Cross transmitter ABC is CH30 (543.5Mhz), as these are later in the spectrum they are put in the LCN list starting at 350.
Posted on Oct 05, 2011
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Polaroid TV is connected to Virgin yet most channels are pixelated and the tv looks like it needs fine tuning, but i can't. Any help?
on the tv screen menu go to display and reset the a settings the larger the numbers the better the picture --apply and ok
Oct 22, 2017 | Polaroid 4241-TLXB 42 in. LCD Television
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
Can't tune in digital channels on JVC
Google the model number if not using a box for specifications to see if the set has a digital tuner or NOT, not all sets do.
Dec 17, 2012 | JVC Televison & Video
Bought a 2nd hand N64 & don't know how to set it up on the tv as no instructions.
You now need to find a channel on your TV that ins't used for anything else (eg an old vhs player or non-digital tv) then whilst on that channel you need to go into your TV's menu, there is often a button both on the remote and TV itself for this. This is where you turn on your N64 if you haven't already. You then will need to go onto automatic tuning (or if you prefer, manual tuning, in the programme section (if you dont have a programme section, just srcoll through each section till you find automatic tuning) your TV should then start to search for channels, after a little while of searching it should find the N64's frequency it may be a terrible picture that is mostly fuzz you can either carry on the tuning to see if it'll find it better or just head straight to fine tuning (if you decied to keep going you can still fine tune for the best picture quality possible and also if the TV doesn't find it just follow the previous steps till it locates the N64 again) once fine tuned you will need to store this new channel and then you can go ahead and enjoy countless hours of fun on the worlds best gaming console. (If the automatic tuning doesn't find the N64 at all try manual tuning). If you have any other issue with the console itself just drop me an e-mail at garleet@hotmail.co.uk. Hope I was a help.
Jan 20, 2012 | Video Game Consoles & Games
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
I don't know how to tune the digital channels in my vcr. I can automatically tune channel 2, 9, 10, etc but not 7mate, 99Go etc
If your unit does not state DVB anywhere, either in the manual, or on the unit itself, and there are no options to tune in digital services via the menu on screen (as well as no EPG), chances are the tuner in it is analogue only, hence why you cannot tune digital channels in it. To receive all SD/HD digital channels, you would need to connect an external set top box to the recorder's AV inputs, and record/view them that way. (Set top boxes are cheaper than upgrading TVs and DVD equipment in many cases).
The only positive point here is it didn't cost you a workshop repair fee or a new unit - the user manual as a pdf for this model is available on FixYa if needed.
Jun 12, 2011 | LG RC389H DVD/VHS Recorder
Sony Bravia Digital TV won't tune Channels 350 and 350, can't manual tune wither as it will only accept 2 digit numbers, even though it tunes 201 ...
May 10, 2011 | Televison & Video
I just purchased a used Sony KDL-V26XBR1 that cannot tune the digital channels over our cable or any signal on the over the air input. Our Samsung, same vintage on the same cable can tune the digital...
Greetings - Your Sony has the standard tuners for a current HDTV, NTSC (analog), QAM (cable), and ATSC (digital/HD) broadcast..
There's something going on with the Sony TV. It's a pretty high end TV so it might have some additional features that require you to do something different (I doubt it) but make sure you've been through the manual.
If you didn't get one with the TV you can download a PDF version HERE.
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Apr 12, 2011 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
76 people viewed this question
Computer Repairing
Computer Repairing
