Question about Initial GM-350 GPS Receiver
Driver for gm 350 - Initial GM-350 GPS Receiver
Can you take turbo 350 transmisson and bolt to a 4.3 moter
YOU NEED A 4L60 E TRANSMISSION, THAT WHAT GM USED. BACK IN EARLY 90S GM USED THM 700 - R4.
Apr 07, 2011 | 1997 Chevrolet C1500
Tip
What is the firing order for GM 350 car?
The firing order for GM 350 car is as follows:-- 1- 8- 4- 3- 6- 5- 7- 2. -------- cylinders set in vertical way as follows:-- 8-6-4-2 in first vertical line and -------- 7-5-3-1 in second vertical line.
This will help.Thanks.
on Mar 18, 2010 | Chevrolet Chevy Cars & Trucks
How to hook up spark plugs to distributor on 1985 350
Firing order on a GM 350 is 1-8-4-3-6-5-7-2. Odd numbers are on the driver's side and even numbers on the left, front to back. #1 is at the 4 o'clock position on the cap, just past a holddown screw, and the distributor turns clockwise. Hope this helps.
Dec 11, 2010 | Chevrolet K2500 Cars & Trucks
What side of the engine is the #1 cylinder on for a 1997 Chevy 350 engine
#1 is the front cylinder on the driver's side on a GM. Hope thishelps.
Oct 10, 2010 | 1997 Chevrolet K2500
I'm trying to find out the horse power of my chevy small block engine 1 GM 14010207
Look at the vin # from outside the car through the windshield on the bottom of the drivers side. The 8th digit in the vin # is the engine code. You should be able to look it up on the internet. I want to say 175hp but i'm not certain. It is usually a letter. For example a small block 350 for certain years is the letter M and I believe small block 305 is P.
May 29, 2010 | 1983 Chevrolet C1500
Gm 350 fireing order
If u can't see the diagram below go to the link to see it.
http://autorepair.about.com/library/firing_orders/bl-fo-14272.htm
Mar 18, 2010 | 1983 GMC C2500
Initial GM-350 GPS Receiver Logo
Top Initial GPS Experts
Are you an Initial GPS Expert? Answer questions, earn points and help others
