Question about Maytag Atlantis MAV6000 Top Load Washer
How to open the lid to washer
My washer is losing water somewere in the back of the washer.How do i find it
If its coming from the back of the tub, its probably the small tube that senses the water level. The easiest way to get to it is through the back panel. To open the lid, slide a putty knife under the lid in the front, about an inch or two from each of the sides while lifting on the lid.
Posted on Oct 28, 2008
Washing machine stops on rinse on all cycles
this could be a timer problem, or the cold water may be shut off.....if it is advancing to the rinse point but not filling, then there may be a problem with the fill valve also. You may want to check the lid switch too, just to be sure it is making contact.From what you are describing it sounds like the problem with your washer could either be the lid switch or no cold water. However there are a number of other possibilities. I would recommend checking the lid switch first. Open the lid & you should see the lid switch actuator mounted on the lid. This is the probe that pushes in on the lid switch as you close the washer lid. Next you can check the lid switch. The lid switch is hidden under the top of the washer. You will see a small opening where the plunger comes down at & activates the lid switch. You should hear the switch click as the lid is being closed. You can also use a small non-metallic probe to push in on the lid switch. If the lid switch is not responding, you will need to replace the lid switch.Next you will need to check & make sure the cold water is turned on. You may want to turn the water off & take the cold water fill hose off of the back of the washer. Use a bucket & turn the water back on to check the incoming water pressure. If the water pressure checks good & the washer is not filling for rinse, you will need to replace the water valve.If you have good cold water supply & the lid switch checks okay you will need to access the inside of the machine to make more checks. Be sure to disconnect electrical power before attempting any repairs. Please resubmit your question if you need further assistance.Good Luck
Oct 27, 2011 | Roper Washing Machines
Wont agitate or drain water to spin
Check to see if your lid switch is working. On most models the lid switch will prevent the washer from spinning with lid open. Some models will stop once the washer fills with water. Depending on what brand you have depends on where the lid switch is. If you need assistance finding the lid switch or replacing it please respond back. Thank you
Aug 02, 2011 | Washing Machines
My problem is the washer won't drain or spin. i saw the solutions and sounds like my problem is the lid switch but it leads to another problem. what and where is the lid switch.
where the lid switch is on the top-back of the washer near the water inlet. you must open the cover. lid position switch associated with the hinge lid-open lid. you must open the screw from the cover. Pull up on the cover, after being released you can find where the lid switch, the location was near the water level sensor. can be used to manually switch, or a light sensor, located under the cover of your washing machine. Hopefully help
Oct 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water comes back in and stands after cycle is run
I'm not sure what washer you have but a lot of washers have an additional spin cycle. If you left the lid open, then it would only fill with water then sit until the lid is closed. Try making sure the lid is closed next time you empty it and see if the water is in there the next morning. I hope this helps. Good luck!
May 25, 2009 | Washing Machines
Motor comes on and water gos out but basket will not spin untill lid is opened then closed again . this is on all spin cycles .
HI, you will need to replace the lid pressure switch. it is faulty or the wires may be worn or lose.in most cases, it will be a faulty lid switch.
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water runs back into tub when lid is opened
not sure what you by opening lid and a large amount off water falls in.i think you mean you open the lid and see water there.If thats so two things one your pump is blocked,youll need to confirm by watching whats happing.Other is the water valve is not sealing so water is dripping in all the time.you would see this when standing there be patient
Dec 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
My whirlpool washer (Ultimate care II) stopped in mid cycle, basket full of water and clothes. There is electricity to the plug, and the washer will add more water, but just not finish the cycle. I...
If the washer fills, but won't spin or drain, you may have a defective lid switch. This is a very common problem and a very common symptom.
Let me guess: The washer fills, agitates, but when it gets to the spin cycle it just stops. On some models the washer will fill and then shut off. Am I explaining your symptoms correctly?
If so, this what you need to do:
Open and close the washer lid and listen for a distinctive "clicking" noise. The contacts on the switch should close when the lid is shut, allowing the washer timer to run. This is a designed safety feature that prevents the washer from agitating or spinning with the lid open (don't need to lose any fingers). If you don't hear the switch, it may have come loose, or has broken.
Some lid switches are located on the right-hand side of the tub rim. There will be a slot where the lid strike pushes down on the lid switch. Make sure the lid strike (small plastic piece) is still present on the lid. This can prevent the washer from working as well and make it seem like a huge problem.
On some models the lid switch is located near the left-hand lid hinge under the washer casing. A small rod on the lid hinge activates the switch contacts.
If you determine the need to replace the switch, follow these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Good Luck.
Feb 27, 2008 | Washing Machines
Maytag MAT12CSDAW
Leep, open the hatch that the timer sits under. You will see the timer and actuator that the coin tray pushes to start the wash cycle. You can rotate this cam clockwise until it gets to it's home position, ususally right around the 12:00 position. Good luck
Jun 20, 2006 | Maytag MAT12CS Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
