Question about Air Tools & Compressors
Diagram to install serpentine fan belt on 185 sullair compressor
It is not a car. It is a sullair compressor
  • 13 Answers
SOURCE: serpentine belt diagram:
if yours has the 3.8L then here is the diagram. Hope this helps
~ Zach
Posted on Jun 16, 2008
warlock61
  • 659 Answers
SOURCE: i need a diagram of 2000 grand marquis serpentine belt
here you go
Posted on Dec 28, 2008
ewashmidas
  • 362 Answers
Here is the one for the 3.9 engine, if you have the other one let me know.
Posted on Jan 29, 2009
ewashmidas
  • 362 Answers
SOURCE: Serpentine belt routing
Here you go.. I looked up the same belt you did, it should be right.
Posted on Feb 09, 2009
old marine
  • 2005 Answers
SOURCE: need routing diagram for 2000 lincoln town car serpentine belt
There's a diagram at this link.
Posted on May 11, 2009
Sullair 185 has oil in air discharge line
The rings of the compressor piston are not sealing.
Dec 08, 2016 | Air Tools & Compressors
Tip
Isuzu serpentine belt routing diagram for 6VE1, 6VD1, Rodeo, Trooper and Axiom...
Serpentine belt routing diagram for an Isuzu V6 cylinder engine. 6VE1, 6VD1 as fitted to Rodeo, Trooper and Axiom
  1. Crankshaft pulley
  2. Tensioner
  3. Alternator
  4. Idler pulley
  5. Power steering
  6. Airconditioning compressor
  7. Cooling fan pulley
on Sep 07, 2010 | Isuzu Trooper Cars & Trucks
How do I install a fan belt
all vehicles are different and we do not know yours . DO WE
Aug 03, 2016 | Cars & Trucks
Sullair compressor 185 cfm diesel
will need the fuel system bleeding loosen the pipes going to each cylinder, when they are all leaking fuel tighten back up it should start then
Sep 01, 2014 | Cars & Trucks
Fix low volume problem sullair 185 does not produce sufficent air to run large jack hammer
Increase the setting on the regulator (on the compressor) or maybe the compressor lacks the cfm output needed to operate the jack hammer
Dec 17, 2013 | Air Tools & Compressors
I have a sullair 185 engine dies and light blinks one and says compressor over heating what causes the compressor to overheat
Hi, my name is John. Welcome to FixYa. Low oil level, and poor air circulation. Thanks for choosing FixYa....John
Nov 22, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
LOOKING FOR WIRING DIAGRAM FOR A SULLAIR 750DP ROTARY SCREW COMPRESSOR. MANUFACTURED IN 1982 FOR U.S.N.
I would contact Sullair factory, they have a great support group that I have contacted not as a Sullair distributor and the still provided me with the information I requested. have the model and serial number when you call them. there number is 1-888-775-1604
Feb 03, 2010 | Air Tools & Compressors
Advice on changing 2004 Discovery serpentine belt
Remove the upper fanshroud, it unclips then pull upwards to remove. Remove the fan from the waterpump with a fan wrench. Also becareful not to puncture the radiator. Then remove A/C compressor pulley(some cars have the ACE pump mounted next to A/C compressor which uses the same cover) cover to completely expose the belt routing. Be careful removing the 10mm bolts. They bolt through two pedastals and often fall. So you have to hold the bolt,cover, and pedastals. There's two bolts holding the cover. This next step is important especially if your car is missng the belt diagram. Draw the belt routing on a piece of paper. Then remove beltension at the tensioner. Install belt around all the pulleys in the diagram except the alternator. Use the same step to install belt on alternator pulley which is always the last pulley to fit belt onto. Then reverse procedure and tighten all bolts.
Sep 12, 2009 | 2004 Land Rover Discovery
Air Tools & Compressors Logo
142 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
