Question about Dell 922 All-In-One InkJet Printer
Paper jams sideways and gets munched up - will not print
It seems one side of the printer has broken inside as the paper no longer feeds through smoothly to print. Instead it goes through lopsided and then gets stuck and scrunched up.We would like to arrange its repair. Can we do this with yourselves?
  • 57 Answers
Check the paper path way , and also leds that directing paper.
hope that help you
thanks
Hamedo
Posted on Oct 31, 2008
Mp499 The paper tries to go thru but only one side pulls it and it goes sideways and gets jammed.
The feed wheels on the one side are either worn out or have some scrap paper stuck on them. Take a good look , after removing the paper tray, if it has one , inside the machine. It might be possible to turn the machine around and see into it from behind, if there is an access door on the back.
Aug 02, 2014 | Canon Office Equipment & Supplies
Hi. I HAVE A PIXMA mp272 WHICH WILL NOT FEED PAPER THROUGH.It appears to jam or stick in the centre then the paper partly feeds sideways but will not feed through. Please advise what to do... Thanks...
this seems like that inside paper path is foreign material. Remove all inks and take printer, flip it upside down and shake it maybe it will fall out. If not, the printer needs to be dismantled, so take it to the service!
Aug 29, 2011 | Canon PIXMA iP3300 Printer
Hp 2610 paper jams on print command. Paper pulls sideways.
find the paper feed rollers and clean them. they get slick and one side will catch quicker and pull the paper side ways.
Aug 12, 2010 | HP Photosmart 2610 All-In-One InkJet...
Canon mx 860 will not print from rear tray: gets
From the symptom,seems that another material (broken paper or something else) block the paper path. Observe paper path carefully and remove any material which blocking the paper.
Oct 10, 2009 | Office Equipment & Supplies
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
Lexmarkx73 Won't feed paper through while printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Paper Jam
i did exactly as iamzwalrus said and it fixed.go with that if nothing eles works.
Apr 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
