Question about Remington 16" Electric Chain Saw
Remington electic chain saw insructions
I have an older remington 3.0 hp electric chain saw and need to know how to assemble chain tightning hardware.
  • 548 Answers
SOURCE: I need a contact to get parts for a Remington EL-7
try here
http://www.masterparts.net/remingtonelectricchainsaw.html
Posted on Sep 14, 2009
dontbother10
  • 2220 Answers
SOURCE: Remington electric Pole Chain saw - what type of oil do I use?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
  • 760 Answers
SOURCE: I need a replacement motor for a Remington
You can buy this complete saw for about 75.00 on amazon. I've heard of others burning up the field and armature in this model saw. You can buy a homelite electric at Home Depot 50-75 depending on model. Doesn't seem like it would be worth fixing, only to have it burn up again. Sounds like it needs a thermal overload to prevent damage. GOOD LUCK1
Posted on Jul 01, 2010
wentlanv
  • 710 Answers
SOURCE: i have a 3.0 hp
Use bar and chain oil, not regular motor oil. Bar and chain oil has an additive especially for chainsaws.
Hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie Andie
Posted on Apr 13, 2011
Testimonial: "THANKS A LOT, JUST WHAT I NEEDED"
hunter19_46m
  • 7482 Answers
SOURCE: What kind of oil or oil mixture do I need to use
Hi brown9148..
The only oil you need for your electric chain saw is "Bar and Chain" oil...specially formulated oil sold at Loews,HomeDepot,Ace Hardware, Auto parts stores,etc...
You use this oil to lubricate the chain and bar of your chainsaw when you are using it.
It will go into the oil tank and auto feed to the chain and bar...but keep a check on the oil level to make sure it is being used.
Refill tank when needed.
Please take time to rate me
Posted on Sep 24, 2011
What kind of oil or oil mixture do I need to use my Remington 2.0 HP 14" Electric Chain Saw?
Hi brown9148..
Sep 24, 2011 | Remington Electric Chain Saw
Remington 18 " electric, The
If its an older saw, it probably worn to the point where the tolerances are so far out that there is too much gap where it needs to be tight. Depending on how much you have in it, it may not be worth fixing.
If its new, I'd take it to a saw shop and have them look at it as you shouldn't have such a problem and it could be a sign of inferior or improper assembly.
Apr 06, 2011 | Remington Electric Chain Saw
Need manual for remington electric chain saw 1,5 hp 14in blade like to know how to tighten loose blade.
There is a slide bolt on the side of all chain saws that allow tightning of the chain. You loosen this bolt and slide the chain bar forward until you can just slide a dime under the chain and the bar. It may take a couple of adjustments as the chain stretches a little after it gets warmed up by the friction of the bar.
Apr 04, 2011 | Remington Electric Chain Saw
What kind of oil does a Remington 3.25 (Peak hp) 16"/40, 6 cm Electric chain saw take
You need to use bar & chain oil. It's thicker and stickier that regular oil so it will stay on the bar and chain and not run out of the saw when you are done using it.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
What type of oil does a remington chain saw use?
Regular bar/chain oil available at home centers, hardware stores, and saw dealers. Hope this helps!
Aug 14, 2010 | Desa International Remington 14" Electric...
What kind of oil for a Remington 12 1-25 hp model INT-2
Use regular bar/chain oil available from home centers, hardware stores, and saw dealers.
Jun 07, 2010 | Remington Electric Chain Saw
What type of oil does remington 3.5 electric saw use
Use regular chain/bar oil available from home centers, hardware stores, and saw dealers. Hope this helps!
May 30, 2010 | Remington 16" Electric Chain Saw
WHAT TYPE OF OIL SHOULD BE USED FOR REMINGTON 3.0 HP ELECTRIC CHAIN SAW?
Just buy regular chain/bar oil at home centers, hardware stores, or saw dealers.
May 29, 2010 | Remington Electric Chain Saw
Lost manual need to know what kind/weight oil does the Remington 16" chain saw require?
Any good quality chain saw 'bar' oil is suitable and it does not need to be an expensve brand either: it is highly recommended that you use a specially blended chain saw 'bar' oil but in emergency you can you fresh 'thick' (e.g. older) car engine oil but don't make it a habit as your chain and bar will wear off a lot faster!
Mar 06, 2010 | Remington 16" Electric Chain Saw Assembled...
Oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
May 25, 2009 | Remington Electric Chain Saw
Remington 16" Electric Chain Saw Logo
146 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
