Question about AT&T Lands Phones
Instructions for At&t 1340 - AT&T Lands Phones
How do you change drive belt on dyna lowrider 2004 mine broke
Take a look at this video. Going to be similar.
Harley Dyna Glide EVO 1340 Drive Belt replacement ...
9k=? 29:10 https://www.youtube.com/watch?v=x4XBILULKck Apr 8, 2014 - Uploaded by Julian Sinclair Harley 1340 Drive Belt replacement on a 1997 Dyna Superglide. ... How To Remove & Install Rear Wheel ...
Mar 28, 2016 | Harley Davidson Motorcycles
2000 Honda Passport check engine light on code P 1340 reads ION sensing module cylinder identification malfunction
Use Google & ask the question
Start with the code & type: 2000 Honda OBD P1340
All the causes & solutions are on the internet, most likely
in about a hundred places
Just remember to study what is there, because codes
have nothing to do with changing parts.
Aug 31, 2013 | 2000 Honda Passport
Power seat has lost power, right side power windows lost power. Can not find the fuse or relay.
there is a bulletin at gm site in regard to this problem. check the wiring near the parking brake ratchet teeth for damage, also check under the drivers seat where the seat bottoms out wiring could be pinched there or the drivers side door sill.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1734688&psdid=1058&evc=sm#ss1-1734688">Condition/Concern:
There have been reports of either the MBEC 1 or LBEC 1 maxi fuse blown intermittently and unable to locate a short to ground.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1734688&psdid=1058&evc=sm#ss2-1734688">Recommendation/Instructions:
If after normal diagnostics no shorts can be found the below items have been reported:
  1. <LI type=1>"MBEC 1" Maxi Fuse 50 Amp (SI Documenticon1.png ID # 1242532). If no shorts are located on circuit 642, inspect circuits 1340 after the "Rt Door" circuit breaker 25 amp and circuit 1440 after the "Seat" circuit breaker 30 Amp (SI Document ID # 1242687).
    • Inspect circuit 1340 shorted to ground near the right I/P support bracket.
    • Inspect circuit 1340 or 1440 shorted to ground on the support bracket for the I/P relay block.
    • Inspect circuit 1440 shorted to ground under or in either front seat.
    • Inspect circuit 1440 shorted to ground near the parking brake pedal assembly. The short may only occur if the parking brake pedal is depressed.
  2. "LBEC 1" Maxi Fuse 50 AMP (SI Document ID # 1242532).- If no shorts are located on circuit 42 inspect circuit 1240 after the "Lt Door" circuit breakericon1.png 25 amp (SI Document ID # 1242687).
    - Inspect circuit 1240 shorted to ground near the parking brake pedal assembly. The short may only occur if the parking brake pedal is depressed.
Note: Replacement of the circuit breaker is needed if a short to ground is found on circuit 3, 1240, 1340, or 1440.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Aug 19, 2013 | Chevrolet 1500 Cars & Trucks
My harley fatboy 1340 has started runing rich after i changed the air filter
If the air filter is not obstructed and is properly oiled, then it should perform adequately. If not, try using the original filter. If the problem still exists, you will need to adjust the fuel/air mixture screw. Do not forget, there are 2 other adjustments... idle and an adjustment to the diafram when you blip the throttle.
I can give instruction on how to adjust, but you should look that up yourself on the website of the carb maker.
Nov 24, 2012 | 2000 Harley Davidson FXDWG Dyna Wide Glide
2001 isuzu trooper code 1340
A 1340 error code for your Isuzu Trooper means that the engine is experiencing a "Camshaft Position Sensor B Circuit Malfunction" which would mean the computer isn't exactly sure where the camshaft is located in it's rotation. If the issue is intermittent then look for a broken wire, if it's solid then the sensor needs replacing!
Good Luck & please rate this solution!
Feb 04, 2012 | 2001 Isuzu Rodeo
Need operating instructions foa a Garmin Nuvi
All User Guides are available for all units at Garmin.com. Navigate to your unit, and then to the download section for that unit. You can also update your unit's internal software at the same site.
Feb 19, 2010 | Garmin Nuvi 205T Sat Nav GPS Receiver
I need tv code for samsung le32r51bd. so i can enter it into sky remote control.
Sky HD Code is 1340 to enter it: -
Press TV
Hold down Select and Red Button at same time until Red LED flashes twice
Press 1340
Press Select and the Red LED will flash twice to confirm that it has been set up.
Now press the Power Button to confirm that it operates properly.
May 08, 2009 | Televison & Video
Lands Phones Logo
133 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
