Question about Radio Communications
Gioteck EX-01 Wireless Bluetooth Headset manual
  • 7 Answers
SOURCE: pairing the insignia bluetooth wireless headset with an ipod
Perhaps either its pairing log is full, thay hold a number of pairing internally, and may need to be cleared to make room for another....or the headset may need to be reset, either way...heres the scoop....to clear the pairings hold the track forward/track backward buttons down together until the light flashes Purple....Empty pairing log......
If not then try pluging in the set to the charger and holing the 2 volume buttons down the same way..this will shut it off and reset it if it went a bit screwy on ya.... Merry Christmas
Posted on Dec 25, 2008
Typus
  • 69 Answers
SOURCE: I cant pair my samsungH200 bluetooth headset with my NOKIA 3600
Is the blue-tooth headset made by the same company, 'cause I think that the headset has to be from the same company, because, well you know, competition and stuff like that
Posted on May 07, 2009
vanherringto
  • 1738 Answers
SOURCE: samsung bluetooth headset manual AATH200HBE
The AATH200HBE is just a charging cradle.
Do you mean the actual headset that sits in the cradle?
If so, it is probably a WEP200?
The user manual is at http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
Posted on Feb 04, 2010
casouzaj
  • 1118 Answers
SOURCE: HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
Posted on May 20, 2010
casouzaj
  • 1118 Answers
SOURCE: PS3 Bluetooth® Headset Wireless Headset: i need a pass key for my bluetooth headset model #...
First try '0000' (four zeros). If it doesn't work, switch to '1234'. It it keeps failing, try '8888'.
Hope one of these codes might suit your case.
Cheers! Carlos
I don't know how to set up my Gioteck EX-01 Bluetooth Headset (PS3)
Got to Giotecks support section on their website
www.gioteck.com/wordpress/?page_id=157
as they are good at providing comprehensive information.. If not you can try their customer service team who are v helpful.
Nov 23, 2010 | Computers & Internet
Where do i find the passcode for my new bluetooth
Here is a helpful link http://www.ehow.com/how_5169210_bluetooth-passcode.html
Phone passcode:
if you haven't actually manually changed it, the password is always the last four digits of your phone number (ex. 1-555-868-2212 your password is 2212). If you manually changed it, you need to call your cell phone provider and have that worked out.
-CompDoctor
Feb 17, 2010 | Just Wireless Bluetooth Headset Wireless...
Passcode236
Phone passcode:
-CompDoctor
Feb 01, 2010 | Southern Telecom Emerson Bluetooth Headset...
I have a lg headset i need a passcode to pair itup what do I do??? I lost the manual
If you haven't actually manually changed it, the password is always the last four digits of your phone number (ex. 1-555-868-2212 your password is 2212). If you manually changed it, you need to call Verizon and have that worked out.
-CompDoctor
Nov 17, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Ps3 mic
Most blue tooth devices use a simple set up code. Try 0000 or 1234. You should be able to change it after it's set up.
Aug 05, 2009 | Motorola Mobility H500 Headset
Ex-01 ps3 bluetooth headset
hi it the option when setting it up, go to thee settings screen for bluetooth equipment and change the output to headset.
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
Headset wont pair with new ps3
is this bluetooth
if it is blue tooth you have to hold blue tooth power on while the pairing mode is searching for headset
if its a cabled headset threw usb you gotta put in your disk for say example= logitech since these are common
the playstation has memmory card that stores the settings but requires you at least set up usb head set parameters either to ps3 or your memmory cards properties
your headset is fine you just require a new hardware setting with the disk that came with your head set
May 28, 2008 | Sony Playstation 3 (PS3) Console
On line chat for COD 4
if it comes through the tv that means your headset is fried or almost. get a different one and maybe it will work if not call sony
May 16, 2008 | Sony Playstation 3 (PS3) Console
Ps3 bluetooth headset
You need to "pair" the headset to the PS3. Follow the instructions for your headset (usually holding down the power button until you get a SOLID blue light) then go to Settings>Accesory Settings>Register BlueTooth Device>Scan. When you're done, you need to set your input device to your Headset model #, which should now appear.
Feb 16, 2008 | Sony Playstation 3 (PS3) Console
Radio Communications Logo
85 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
