do you have remote start needs different programming then simple lock unlock and most locksmiths dont have that programming also is the for actually for your vehicle if have regular lock unlock below is how to program also when battery changed need to reprogram fob How to reprogram my Honda key fob insert the key into the ignition and turn the key to the "on" position. Press and hold either the "lock" or "unlock" button on the remote for one second. Release the button on the remote and turn the key in the ignition to the "off" position. Repeat this process two additional times.
First you need to find the program button or input button. Almost all universal remotes are the same process for programing.Aim the remote at the tv and push the tv device button once then use the program or input button push and hold till the light blinks twice or stays on then put in your 3 or 4 digit code and press enter.
The BCM will keep 3 remotes in memory. It takes about 30 minutes to program it without a GM scan tool .The stealer(dealer) will usually do it for an hours labor whatever their rate is. To do it yourself : turn the key on till the security light goes off, press the remote lock button and hold it while turning the key off.Wait a minute then repeat the process 2 more times . The 3rd time the lights should flash and the horn honk and your done.
The PATS bypass module should have disconnected during the new key programming. First, you need two programmed keys present. Put the first key in the ignition, turn ignition on, wait for security light to go out. Remove key, immediately put second key in the ignition and turn ignition on. Wait for the security light to go out, remote start vehicle with controller, immediately remove key. Let the vehicle start and run for approximately 10 seconds. Apply brake to shutdown, wait approximately 10 seconds. Remote start to test. If vehicle does not start, repeat process.
Press and hold the component button you want to program enter the four digit code. Release the component button. Press the power on/off button to see if it works. If it doesn't repeat process with the other codes. 1003, 1054, 1062, and 1170. If this helps let me know with a vote.
