Question about Canon Office Equipment & Supplies
ERROR CODE E00056F-002
IR 5030
SOURCE: Canon IR 3030 error code 000 002-0000
This code is for the fixing area. I have found that most times it is the lower pressure roller bearings that have seized up and need to be replaced. it could also be the main thermistor has a problem, it would have to be replaced or cleaned ( try cleaning first). on the rare occasion a retaining clip has broken and had jammed the upper roller. The best thing would be to check everything in the fixing area. it is under the yellow cover that gets very hot.
Posted on Mar 07, 2009
  • 109 Answers
SOURCE: error code E00001-002
enter service mode by:
* then 2+8 then *
function
clear
err
ok
turn off then on the device
Posted on May 27, 2010
muleskinner2
  • 270 Answers
SOURCE: IR 6570 Error occurs E804-002
This is an error for the DC power supply fan - there is an IH power supply cooling fan error. The book I have doesn't give the 002 part of the error but check that
Posted on Jun 21, 2011
canontech
  • 1219 Answers
SOURCE: My canon machine is IR 3035 and having a error
this is error code for abnormal temperature rise in fixing section.
You can try to reset error in service mode, but if the problem persist you need to change the fixing film unit.
To reset the error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose: COPIER>FUNCTION>CLEAR>ERR.
Turn off and back on.
Hope that helps!
Posted on Aug 22, 2011
roumellacand
SOURCE: CANON IR C5870 ERROR 000202-002 HELP ME
canon IR5870i error code E000070-0102
Posted on Feb 16, 2012
Error code of E-002-0000 canon printer IR 2002
Here is a link that I hope addresses the fix you need by the error if is an issue with the temperature of the fixing unit
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Aug 24, 2016 | Canon Office Equipment & Supplies
How can i fix the error code 000001-00002
Assuming you have a copier or laser printer, this site:
Thread Canon IR 2200 error E000001 002
suggests:
Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Jan 11, 2016 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Error code 002-0000 for canon ir 2202
Hi
A website I have found gives the details of this error for the IR2016 and the IR2022 as the same.
Description Low temperature during temperature control.
The target temperature is not reached during temperature control. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Amongst other codes you can find it here:
Error Codes Canon iR2022
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon iR 2016i Black and White Copier
Canon ir 3300 error code E000805-002
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3300&code=E003-0000
Oct 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Jun 21, 2011 | Canon imageRUNNER 5570 Copier
43 people viewed this question
old marine
old marine
