Question about HP Compaq Business NX9110 Notebook
HP Compaq nx6325 notebook, won't power on
The LED doesn't come on when AC is plugged. The computer doesn't recognize power from AC or battery, will not power on.
  • harbos Jan 03, 2009
    I have the same problem, also with HP nx9110! Already changed mij battery, but didn't help. Problem could be the DCconnector, but not easy to change it on the motherboard.
enda story
  • 61 Answers
SOURCE: hp compaq nx6325
try another power supply or try it with out the battery
Posted on Apr 21, 2008
  • 14 Answers
SOURCE: On HP 530 notebook battery/power
Clarification of your battery/power led indicator:
Solid amber:
Battery is charging at 0% - 89% capacity
Solid green:
Battery is charging at 90% - 99%
Blinking amber:
Battery is low
Led is of:
Battery is charged
Posted on Dec 12, 2008
  • 8 Answers
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Posted on Apr 28, 2009
stif_NEC
  • 441 Answers
SOURCE: hp compaq nx7400 - battery died and power cord will not turn comp
If your system won't boot up with just the AC adapter connected, it means to say that there's a problem with the AC adapter or the motherboard of the computer. Basically, if the AC adapter or the motherboard is damaged, you won't get a charged battery. If there's another AC adapter that you can try your computer with then that will be great. If antoher AC adapter works, then you just have the AC adapter replaced. If a known AC adapter didn't work then you may need to consider replacing the motherboard of the computer.
Posted on May 07, 2009
  • 115 Answers
SOURCE: Installed wrong version bios on HP 530
u can try reseting the BIOS.onlyt option is taking out the CMOS battery and then putting it back but in tat case u hav to open up u r keyboard ,,its a bit risky,,so u better call up tech support for locationg the CMOS battery
Posted on May 14, 2009
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Nx6325 battery
If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by using Device Manager
1.Open Device Manager
Right click on My Computer->select Properties->click Hardware tab->click Device Manager
or if you're using Vista or windows 7,type "device" on the Start menu and select Device Manager
2.Expand the Batteries category
3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Aug 17, 2012 | HP Compaq nx6325 Notebook
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
I am unable to charge mt battery on an HP Compaq nx6235. It will not work even with the power cable pluf=gged in. Tried everything but unabke to get any power
You can try hp compaq nc6120 battery as a replacement battery for your HP COMPAQ laptop. The Business Notebook NC6120 battery meet or exceed the original Business Notebook NC6120 notebook/PC batteries. Buy this rechargeable Li-ion HP COMPAQ Business Notebook nc6120 battery pack is cost-effective now.
Sep 14, 2011 | HP Compaq nx6325 Notebook
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
Power on password wont allow me in
Call HP and prove to them you're the rightful owner and maybe they can help you. This is a feature to prevent someone stealing you pc and using it. Sorry this is the solution.
Jun 13, 2009 | HP Compaq nx6325 Notebook
Hp compaq nx9110 runs only on battery when it is plugged to AC
Apr 28, 2009 | HP Compaq Business NX9110 Notebook
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
My hp compaq laptop nx6325 refused to charge its battery. It works normally with the ac adapter but goes off whenever I remove it from the ac circuit. The same battery was taken to similar laptop for...
If the battery charged in another system, but not in yours, then most likely you are looking at a motherboard replacement.
Average cost for motherboard is around $200, if you have it installed by a technician, another $100 or so.
Feb 28, 2009 | HP Compaq nx6325 Notebook
HP Compaq Business NX9110 Notebook Logo
199 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
