Question about LG WM2301HW Front Load Washer
Override tE alarm on LG washer - LG WM2301HW Front Load Washer
2 Suggested Answers
SOURCE: te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Posted on Jan 10, 2008
My lg top load washer has a te code but I don't know how to take cover off to check wire
tE error is thermistor problem. Check out repair videos on repairclinic.com or appliancepartspros.com or YouTube.com.
Feb 23, 2018 | LG Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
LG wm2487hrm Washer not draining water. tE flashing. I drained water out of front and ran 2nd cycle same issue.
tE is a thermister error. It is a temperature sensor at the bottom front of the washer. tE can also be caused by a heater error. Some models have a seperate thermister, some incorporate it with the heater. It is very difficult to replace without taking the front off the machine.
Jan 25, 2011 | LG WM2487H Front Load Washer
Te error pops up washer stops clothes still in it already drained filter not that bad
the thermistor is busted te means thermistor error need service technician tough job
Jan 05, 2011 | LG WM-2277HW Front Load Washer
Lg rom reads error code te
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 21, 2009 | LG WM-2277HW Front Load Washer
TE message. machine turns on but nothing else. I found out the message means a thermastor problem
Perhaps the error is "[-E" and it means the thermistor is out of error. Replacing it will correct the problem
Apr 27, 2009 | LG WM2277H Front Load Washer
Washer machine
Sorry for the late response. (Cold windy Sunday, and I was just browsing old posts and found yours) The tE error is thermistor error. It is a small sensor right by the heating element at the front bottom side of the outer tub which tells the control what the temperature of the water in the drum is. Part number 6322FR2046C and it is not very expensive. You have to clip a nylon wire tie to remove it, but it just unplugs and then pulls right out from a rubber holder. You might be able to access it by pulling the washer out from the wall about two feet and leaning the washer back to the wall, then looking up from under the washer. (the standard approach is to remove the washer front panel, but I think you should be able to do the change out a lot faster with the tip it approach) Good luck.
Oct 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Te error on LG frontload washer
Jan 10, 2008 | LG WM-2277HW Front Load Washer
LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Sep 12, 2007 | LG WM2688H Front Load Washer
LG WM2301HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
