Question about Bosch ProTankless GWH C 800 ES LP Tankless Water Heater, Propane
Bosch backflow temperature sensor mod gwh c 800 ctdr efs lp
ERRA CODE E4
2 Suggested Answers
SOURCE: I have a Bosch GWH
A lot of factors, internal and external, can cause this problem ranging from bad PC board to plumbing problem.
Since you have no error code, it could be plumbing,
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Open following link for useful Bosch troubleshooting information including Bosch support and typical manual for 2700 gas tankless:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For folks with Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 26, 2011
How do i gas heater gwh 2400 ctd efs Lp
Stupid me but could you be a little bit literate in asking a question.
My dog write better questions that I can understand than this scribbling.
A GWH 2400 is the little brother of the GWH 2700 much like the 635ES. If you have an LP model be sure to use the overpressure protection valve supplied by Bosch as overpressure in LP (above 10-14" WC) can completely destroy this unit.
And you can use a TPR or PRV for 170,000+BTU being sure you get a House Pressure valve of 60-80-100 PSI+ and not the boiler PRV for 30 PSI
Beyond that your questions above states nothing recognizable as a technical question
Oct 19, 2014 | Bosch & Tankless LP Hot Water Heater
Won't heat water
Glad it worked out so easily.
Be sure to perform the regular maintenance as shown in manual to prevent common error codes.
Sep 25, 2012 | Bosch ProTankless GWH C 800 ES LP Tankless...
Where can i download a GWH 715 ES manual?
Are you looking for sell sheet pdf, or install-care manual, or service manual.
Search: GWH 715 ES manual .pdf
Adding .pdf to search parameter helps locate manuals.
Sell sheet with venting overview, technical and product specs:
http://www.globaltowne.com/manuals/sell_sheets/715-800SellSheetFINAL.pdf
Manual for ES high altitude, with installation, error codes and troubleshoot:
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
I cannot find a service manual, or service bulletins:
http://www.bosch-climate.us/support-center/downloads/bosch-manuals/earlier-models.html
Aug 11, 2011 | Bosch ProTankless GWH 715 ES LP Tankless...
E4 code on a bosch ghw 715 control unit
Before calling service technician, open following link for Bosch troubleshooting resources:
Error codes are starting point for troubleshooting, and solutions vary by model and unit.
E4 is Backflow temperature sensor over 309 degrees F. Appliance will close burner and lock.
Check combustion air and backflow vent piping for blockage.
Check if secondary fan connections are disconnected.
Check venting specifications are met. Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure.
Check sensor resistance
Upvote the help.
And take advantage of fixya expert assistance live.
May 29, 2011 | Bosch ProTankless GWH 715 ES LP Tankless...
My Bosch GWH 425 EF will not ignite. Have had this water heater 3 years - it is happening more & more, plumber that installed it says it supposed to do this....pretty sure it's not.
im leaning towards the thermo coupler its like a eye only it measures the heat at the pilot tight if it tells the unit its off it shuts down and turnes the gas off thats why you have to keep relighting hope this helps.
Apr 26, 2011 | Bosch GWH 425 EF L Water Heater
I have a Bosch GWH 2700 CTDR EFS NG and the water will not get hot and if it does, it's only for a brief moment.
Mar 26, 2011 | Bosch AquaStar 2400ES-NG
What does Error code A3 mean and how to correct it ?
http://www.bosch-climate.us/files/201008311810050.G3-11_A3-E3_Error_Code_Troubleshooting.pdf
Check out Link for help.
I have same problem.
Oct 24, 2010 | Bosch ProTankless GWH 715 ES LP Tankless...
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
Bosch ProTankless GWH C 800 ES LP Tankless Water Heater, Propane Logo
27 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
