How to hts3510 reset - Audio Players & Recorders
  • wilson_soare
    wilson_soare Feb 16, 2012
    My HTS3510 is not responding at all. I can turn it on but no commands is possible. There is a internal reset key or battery to disconnect?
I need a new power supply unit for philips dvd hts3569/98 home theatre system that got burnt
WOW! Your power supply is exotic!... You MAY have better luck searching for similar supply models shown below? They all (apparently) all use the same supply. Methinks chances of finding a used one are quite slim.
I WAS able to locate a SERVICE MANUAL for:
Home Theater DVD Player HTS3510/12/51/55/78/93/94/98
PAGE 7-1
shows a FULL POWER SUPPLY SCHEMATIC WITH voltages and part numbers ~ YES!
Know there are FIVE different voltages provided FROM the supply... which ONE or ONES are missing?
The TROUBLE SHOOTING CHART is very well written and should help you greatly!
Most of the parts appear to be 'standard parts' except for the 2 transformers!
From memory, T501 and T502?? Don't quote me on that.
Trouble Shooting Chart.......................................................5-1
Anthony
http://diagramasde.com/diagramas/otros2/PHILIPS-HTS3510.pdf
Dec 14, 2017 | Philips Computers & Internet
Tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
on Sep 27, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Hts3510 remote control
Check your remote control for its infrared emission. If there is no infrared emission, the remote won't work. Check it with fresh batteries. Clean your remote control in necessary. The procedure of cleaning a remote is described in detail in the site named Electro-help. Check this link and select the site named above. Pull up older posts there.
Jul 08, 2012 | Philips Televison & Video
Region code breaker for Philips HTS3510 with no remote
how can i region free my philips hts3510 plz give me solution
Mar 16, 2012 | Philips Televison & Video
Can't get tv audio through my Philips HTS3510.
Here is the user manual and quick start guide:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=ph&ctn=HTS3510/98
Be sure your connections are correct.
Press AUDIO SOURCE repeatedly to select
the audio output of the connected device (TV)
There could be audio settings on your TV which you can select only Internal or only external speakers or both. Be sure the setting is correct on your TV.
Be sure your TV and your HTS3510 are not set to "mute"... Don't laugh... I've done it before...
Jun 09, 2011 | Philips Televison & Video
I just bought a philips hts3510 home cinema and i just found out that it doesnt take any dvds with region 1. Is this the fact that these years such dvd players do not support multi region dvds?? Im very...
http://en.wikipedia.org/wiki/DVD_region_code
"The commercial DVD player specification requires that a player to be sold in a given place not play discs encoded for a different region".
If you don't live in Region 1 and you know most DVD's ARE Region 1, it would make sense that some care should be taken to buy DVD's compatible with YOUR region.
Feb 19, 2011 | Philips Audio Players & Recorders
Philips HTS 3164
Search for hts 3154 ....
Aug 13, 2008 | Televison & Video
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
91 people viewed this question
 Grubhead
Grubhead
