How connect minolta c606e with scart to iMac
This camera (purchased in 1991) has an output lead to scart. How can I connect this to an iMac. I have bought an Elgato Video Capture device for the iMac. This has an SD lead and the three red white yellow jacks. I can't use the SD lead but can connect the jacks to a scary. I also have a DVD/CD player with various input and output connections....
  • Mark Madeley Feb 16, 2012
    If anyone looks at my question and knows I have omitted a vital piece of information, please please let me know!!! I am running a MAC OS X version 10.7.3
3 Suggested Answers
carpenocte
  • 104 Answers
SOURCE: Toshiba DVD-CD SD-R2212
if the problem is that the optical unit do not read, then it might be just dirty... try with a cd cleaner... you can buy it its very cheap... if you have some other problem, like good reading but not recording... I would need more information because it could be caused by many things...
Again if after cleaning it still failing... and that is the only problem, you should take it to a technical service center.
Posted on Aug 05, 2008
  • 6 Answers
SOURCE: VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Posted on Aug 18, 2009
Testimonial: "Very comprehensive, just want to make sure I don't need the black cable connection"
How do I connect my sky to tv
Without specifics on your TV or SKY box I can only offer general information. The SKY digital satellite receiver will have a number of outputs for connection to your TV. There will be a co-axial output similar to a TV aerial connection which is for older TVs and most flat screen TVs won't be able to tune into this RF output. There will be a large black rectangular connector which is a SCART connector and this can usually be connected to most flat screen TVs with a suitable SCART lead. There should also be a small connector called a HDMI output which is now the most common way of connecting to flat screen TVs, requiring a HDMI lead. Depending on which method you use to connect to the TV, you then use the TV remote control to select the input you used, which could be listed as SCART, AV1, AV2, HDMI1, HDMI2 etc.
Jan 03, 2016 | Televison & Video
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
We want to connect our Sanyo VHR-795E to a recently purchased LG freeview TV to record programs. Our best efforts so far have resulted in recorded picture but no sound in playback mode. We have tried...
Some TV's have different settings for outputs at scart sockets. Read the manual on the TV to see if it mentions what the scart(s) sockets output.
However I think you might find it better to connect your VCR to a seperate Freeview box, that way you can watch a different channel to the one you are recording. Box's are cheap at the moment you can get one for around £10 on E-Buyer.Com.
Aug 23, 2011 | Sanyo Televison & Video
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
VCR playback to TV
Has the TV got more than one scart socket? If so try a different one, as some are not designed for VCR playback. Also the scart lead must be fully wired, check that it's not damaged (look at the pins carefully). Scart leads are good at causing all sorts of trouble, so make certain you have a good quality new one connected.
Feb 19, 2010 | Televison & Video
I would like to know how to connect a dvd player through my samsung vcr the inputs in the back i am not familiar with there are two sets of yellow white and red connections with one side for output and...
Connect from dvd OUT to vcr IN
The yellow connecter is video, red is right audio and white is left audio.
You can purchase converter leads (scart to phono(the red/white/yellow connecters) or many other combinations) if needed.
If you have scart connections ( a block of 21 pins) then use that if possible as it will give a better picture.
Connect the dvd out to vcr in and vcr out to the tv in.
NOTE. if you connect this way you will find that the copyright protection will make viewing dvds quite poor quality and may even be black and white or even the picture may "roll"
You may want to buy a scart block to connect more scarts to the tv then it has, also you can get these with different connections.
Dec 30, 2009 | Samsung VR8607 VHS VCR
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Has philips VR765 composite video out on scart connector?
you will need to get this to make the scart a composite connection http://www.svideo.com/scart.html
Jan 05, 2009 | Philips VR750 VHS VCR
Connections
You can buy a scart to phono plug (in/out) at surf4pay. price around £2.50
Aug 28, 2008 | Ulead Videostudio 8 for PC
Video output from VHS recorder
does your television have multiple scart connectors? Sometimes some models have only 1 connector that will accept RGB signals... Another thing you can check are VCR settings - scart component video output is not "official" and hence you might need to look at some of the setting if you need to enable it. Another possibility is that your scart cable may not have your rgb signals connected (based on wikipedia reference: "not all SCART cables make use of all the pins, often leaving out RGB signals. In many cases there is also no way to see which type of signal that is currently displayed on the TV set."
May 05, 2007 | Zio Corporation CameraMate RealTime...
60 people viewed this question
k24674
jasbo
jasbo
