Question about Siemens Washing Machines
Siemens S 12. 49 manual
My washing machine has stopped working, it keeps coming up with a code- F.18 its half full with water and i cannot open the door to even drain it in order to get my clothes out, this is really annoying, please help and send a manual :(
  • 1294 Answers
SOURCE: Candy washing machine fills with water when not on.
Do check your outlet filter, this requires periodic cleaning according to your usage. Refer to your user manual re cleaning filter.
Posted on Oct 07, 2007
SOURCE: faulty door which keeps beeping
I had a similar problem which was resolved by replacing the door interlock switch (cost about £10.00).
To get to it you need to disconnect the mains then remove the top lid. You can then see it by looking down the inside to the right. Remove the 2 screws inside the door opening and you can then lift it out after disconnecting the wiring plug.
Replacement is the reverse of the above, a 5 minute job.
Posted on Dec 29, 2007
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Posted on Apr 04, 2008
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
Siemens avantgarde washing machin stopping at rinse stage
Does the washer pump out the water after the wash cycle? If not then check the drain lines coming from the pump to make sure that they are clear. Your pump not pumping will cause the machine to stop working as well
Mar 23, 2014 | Siemens Washing Machines
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
My daughters washing machine of 3 yrs old keeps stopping and flashes F 18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine..
Open flap at the bottom righthand flap.
Keep big bucket handy for water.
Remove clear plastic attached to black tube (slowly)
This will empty water from washing machine.
Once empty - no water coming out from washing machine then open big opener next to tube and remove any objects inside( coins, buttons and such)
Put back clear plastic filler firmly inside as before.
Close big opener next to tube.
close flap
Turn machine programe knob to DRAIN.
Start washing machine.
Should do the trick....
Good luck
Apr 01, 2011 | Washing Machines
My siemens washing machine S14.39 keeps stopping at display F:18
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
May 18, 2010 | Washing Machines
I have One and Half year old siemens E12-46,7Kg.,1200 RPM,Front Loading Washing machine,we are getting code F-17 everyday,pls advice for resolve F-17,
Check your water pressure, ensure that the valve on your machines water supply is fully open and that the hose is not kinked when you are pushing your machine into the wall. Also unscrew the water hose from the back of your machine (dissconnect the mains first) and check the filter for debris.
Hop this helps.
Mar 01, 2010 | Siemens WM14S794GB Front Load Washer
Not quite enough water getting into the machine. Some washes coming out with dry patches on the laundry
hi when doing wash are you sure wash load button is set for full load and not half load ? as half load is less water used and wash time can you hear water entering machine clearly when on ? also check the tun on/off tap for wash machine pipes are fully open as well as the main water supply stop **** for your abode ?
Nov 01, 2008 | Washing Machines
Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Oct 19, 2008 | Siemens WXLP1460 Front Load
Whirpool washing machine
The FP code just means that your filter is clogged or has a hair doo-dad or something in it that needs to come out. There are Guys on YouTube that will show you how to do that, step by step, just google Whirlpool AWM8103/1 fault codes to see them. Tip* Have a Large but Shallow pan or container of some sort ready to catch the water that the filter will be holding in it's line because it will come rushing out when you open the filter housing! Towels will be useful. Merry Christmas!
Dec 03, 2017 | Whirlpool AWM8103/1 Front Load Washer
Oct 07, 2007 | Washing Machines
Washing Machines Logo
55 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
