Question about Honda Electrical Supplies
Remove mecc alte spa alternator from honda - Honda Electrical Supplies
2 Suggested Answers
SOURCE: Getting NO power from the MR2 160/2 Mecc Alte Spa
There are a few more components to check in the system. From the information provided this is not a Kohler generator as Kohler makes all their own AC alternators under 350KW, seems you may have just a Kohler engine (probably a CH25). Cannot find any info on the voltage regulator which leads me to believe it may be integrated into the main controller. Curious to know who the manufacturer is. If the capacitors are good, try checking the diodes. A volt/ohm meter with a diode check will do. Voltage reading on one side and nothing on the other. If you have no access to a diode check feature, try reading it through a battery NOT SHORTED TO BATTERY hook a meter to a battery and put the diode between one of the leads to the positive, one way will read voltage the other will read open, no voltage, or OL. Look for any fuses or breakers blown / tripped. 6 VAC on the output is about residual voltage meaning voltage the alternator makes without any help from a voltage regulator or field voltage. This usually means the alternator / rotor windings are still good. This alternator is brushless so you could seperately excite this unit via a 12V battery through your field. Look for your exciter field winding, it should have some kind of label on it saying F+ and F-, apply 12V here momentarily on + & - respectively with the unit running and you should see your output voltage spike. This tests the alternator. If this tests ok, then check to make sure your wiring / fuses from the alternator to the controller or voltage regulator (voltage sensing leads) are ok. If all these check ok, it is likely you have a bad voltage regulator.
Posted on Jul 16, 2011
I need the capacitor for a Mecc Alte Spa Generator Type T20F-200A 15KW
Take the specs off the capacitor and look it up on-line. Should be able to find one easily. You can also try your local electrical supply house.
Feb 28, 2015 | Electrical Supplies
ENGINE CUTS OUT, AS NOT CHARGING BATTERY.HOW DO I CHECK, CHARGING SYSTEM ON THIS MODEL?
you will require access to the end of the alternator from the drawings on the pramac site the alternator looks like it could be made by mec alte spa if so there are spec sheets on their site for the alternators, remove the end cover of the alternator and there should be a bridge rectifier in there which will need testing also the spec sheet should give the resistance of the coils so you can check them you will need info from the data plate on the alternator, if it is mec alte spa then find your product herehere
Oct 30, 2013 | Pramac P6000 6000w Super Silent Enclosed...
Honda cr-v anno 2005 motore 2.2 td cambio mecc. 6 marce forte vibrazione (in accellerazione tra 80 e 100 km/h) all'avantreno
La prima cosa da controllare ? le gomme, di equilibrio, di turno, rottura della cinghia (in gomma) ect. Successivo controllo motore monta ??
Sep 08, 2011 | Honda CR-V Cars & Trucks
Getting NO power from the MR2 160/2 Mecc Alte Spa altenator stator. Generator repairman said he didn't find anything wrong using his voltmeter. Measured 6 vac out. I tested caps and they seem good....
Jul 15, 2011 | Kohler Electrical Supplies
On 92 honda civic the battery light stays on. Is
No your alternator is not longer working correctly. It could be as simple as a broken alternator drive belt. Open the hood an see if you see any naked pulleys. If the belt is in place then you most likely with have bad alternator. NAPA and Autozone have stores that can test your old alternator. Con comeone into removing it and have it tested. If it is bad get a REBUILT one. A new one will cost a small fortune!
Jan 21, 2010 | 1992 Honda Civic
Alternator replacement
TO REPLACE THE ALTERNATOR YOU WILL HAVE TO DISCONECT THE BATERY AND RAISE AND SUPORT THE CAR FROM THE FRONT LEFT END AND REMOVE THE TIRE AFTER THAT LOSEN OF THE ALT BELT BY LOSENING AND REMOVING A SHORT 12MM HEAD SCREW ON THE ALT ADJUSTER ON TOP AND LOSENING AND REMOVING A LARGE 14MM HEAD SCREW ON THE BOTTOM AFTER THAT PRAY THE ALT WITH A BIG FLAT HEAD SCREWDRIVER AFTER THAT TAKE OF THE ALT SUPORT TO LET THE ALT COME DOWN THE SUPORT IS BOLTED TO THE ENGINE BLOCK WITH 2 SHORT 14MM HEAD SCREWS, AFTER THAT YOU CAN TAKE OF THE ALT CONECTOR AND B+ CABLE NOW YOU CAN REMOVE THE ALT . INST INVERSE
Oct 03, 2009 | 1989 Honda Civic
I need to replace my alternator
You need to first take off youre serptine belt. Inspect that and generally its a good idea to replace. Next there is a electrical connection on the alternator. DISCONNECT the battery FIRST!!!!!!!!!!!!!!!!!!!!!!!!! then disconnect the connection on the alternator, there are a couple of bolts that attach the alternator to the engine. and then simply bolt on the new one, re-attach the electrical connection and then re-install the (new) belt.
Aug 20, 2009 | 1992 Honda Accord
How to replace 83 honda accord alternator
The very first thing you need to do is disconnect the 12 volt battery source, remove the positve lead as well as the negative lead to be absolutely sure, you must be careful, I would wear safety glasses as well cause anytime you work around batteries there is a possibility of spark and ignition that can cause the gasses produced by a battery to explode sending battery acid into the air and on ones self.
Next locate the alternator adjustment bolts , wire leads connecting to the alt. mark those necessary wires so that you will be able to install them back into their proper place on the new alt. remove alternator belt and note conditon, often this is the best time to replace it with a new one. once you have all bolts loose thne you can lift the alternator from it's rest , take careful note of any spacers used on the pivot mount side of the alternator as well as any wire leads connected you could not see from above. replace in opposite mannor as removal... hope this helps..
Aug 04, 2009 | 1983 Honda Accord
Need a diagram for this overcomplicated machine
Will probably bin it. Long experience shows that the ONLY alternators worth having are the British made Newage-Markon which IMHO are superior to both Sawafuji and Mecc-Alte. Voltage Dependent Resistors (VDRs) also known as Transorbs are essential if long term reliability is desired from small gensets. Haverhill Generators get around the voltage spike problem another way - 8 microfarads across the output but one Haverhill generator that I repaired had vibrated apart its control box wiring and fan. These little machines all leave a lot to be desired unfortunately and seem to give endless trouble.
Jul 30, 2009 | Office Equipment & Supplies
How to change an alternator on a 1989 honda
Disconcet the positive cbl on batery..
Disconect plugs & wires from alternator..
Loosen the belt.
Undo bolts..
Pull out alt..
Put in the new alt..
Tighten bolts & belt.
Plug wires back in..
Re-conect cbl to batt..
Hope this helps !!
rate me good ;o)
Jul 13, 2009 | 1989 Honda Prelude
Electrical Supplies Logo
94 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
