Question about Kenmore 19233 Computerized Sewing Machine
What needle to use
I have an old Kenmore 158 sewing machine. I have several needles and I don't have the original book. What color needle do I need to sew polyester material? My otions are purple, green,blue and orange. Thanks
    Problem Solver:
  • 8 Answers
You should use a blue needle or a ball point needle for when sewing knits or synthetic fabrics.
Posted on Nov 06, 2008
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
HAVE KENMORE MODIFIER- THAT IS ALL IT HAS ON IT -- NO NUMBER - i NEED TO KNOW HOW TO SET THE STICTHES . AND BASIC STUFF
Have never heard of a Kenmore "Modifier," but if you search the internet, you may find information:
Sew with Kenmore Modifier
Kenmore Sewing Machine Instruction Manuals and Repair Manuals
Kenmore 1357 Instructions Manual
Even if you are unable to find a manual that matches your machine, frequently the models are very similar and may be enough to be helpful.
Apr 27, 2016 | Kenmore Sewing Machines
My needle keep breaking
First, be sure you are using the correct size needles for your machine (most likely 130/705 H)--not all needles will work in your machine. (Consult your owner's manual.) Make sure you are installing the needle correctly. Usually, the flat part of the needle should face the back of the machine. Also, be sure you are pushing the needle up all the way before tightening the screw.
Here's an info guide about types of needles:
http://www.schmetzneedles.com/learning/pdf/schmetz-needle-chart.pdf
May 18, 2015 | Kenmore Sewing Machines
What kind and size needle should I use in my Kenmore 158 14300 machine
Needles are sold at WalMart or other stores. The needle size is depending on what you are going to sew. The needles have the sizes marked on the package. The type of needle that your machine uses is a standard needle for sewing machines; no special type.
May 03, 2015 | Kenmore Sewing Machines
Bobbin is not working
try rethreading the machine top & bobbin
make sure the bobbin is not warped
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
if these suggestion don't help then the machine may need to be
checked to see if it's out of time
Jun 06, 2012 | Kenmore Sewing Machines
How to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Jul 24, 2010 | Kenmore Sewing Machines
Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
Oct 25, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Kenmore 19233 Computerized Sewing Machine Logo
Top Kenmore Sewing Machines Experts
Bargain Box
Bargain Box
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
