Question about Moulinex DDF444 Optipro 6Speed Handheld Blender
Moulinex optipro parts
The black plastic part that goes on the end of the motor drive shaft that the attachments fix on to - the end that attaches to the motor shaft has sheared, is it possible to get a replacement for this part?
Any ideas how I remove both the mixing bowl & blade that won't release from my hardly used (maybe 10x's) Kitchen Aid Food Processor?
It sounds like the blade has become jammed on the motor shaft sleeve. You will be up for a new blade and motor shaft sleeve to sort that out. They are not expensive and it is the only proper fix for them. If you replace nothing it will happen again pretty much straight away and if you only do one the other damaged part will wreck the new part. To solve the not turning on problem which is a separate issue it will very likely involve replacement of either the bowl or the lid. One is as likely as the other, I have both parts in stock so I try one or the other to decide which one is the problem. Getting the blade off is a real chore, I have a small chain (with welded links so very strong) I put a couple of turns around the big blade shaft and fix it there with a shackle. It's about 2.5 meters long so I attach the other end to the leg of my bench and accelerate the motor unit away from the bench. The chain comes tight and shocks the blade off. I then drill a hole through the motor shaft about 8 mm from the top, attach the chain to that with a shackle and shock it off just like the blade. New parts now and job done.
Nov 20, 2015 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
Moulinex turbomix spare part
Check with Moulinex for the part you need
Jun 25, 2013 | Moulinex Turbo Mix Plus, plastic, 220V
Braun type 4191 blender shaft coupling faulty
I had the same problem, the authorized service told they cant fix it, so i tried it. First, I show you the solution:
You see the black one you attach the heads to. The axis come from the motor with the little teeths: the black plastic wore away that's why the motor works but the end doesnt rotate.
You can simply pull the black one out with a pliers with medium force and if you get a new one(thats the hardest, they wont sell you) that will works.
For the mankind, ive totally flatten out my type 4191, so i show you some pics, how to solve yours:
if you had problem with the motor, simply cut it half. You wont harm anything, the motor is in a metal cylinder.
If you have some promblem with the electronic part, its in the end of the blender. You can open it at the top, but you cant reach anything form there, nor here, sad story.
finally some photos from the bottom:
Enjoy it!
Jan 06, 2011 | Braun MR 550 M MultiQuick Handheld Blender
Bamix hand blender 2 speed
I found this rubber drive coupling on mendshed which were helpfull enough to place it on their ebay site for shipping outside of the US. Check if it looks like yours first. One end the tapered end screws into the drive shaft the other end just fits in the rectangular shaft of the motor.
Sep 08, 2008 | Bamix Blenders
Philips Hand blender
My wife picked ours up at a rummage sale, and we've grown to love the little thing for making single servings of banana milk shake. (half a frozen banana, cover with milk, a drop of vanilla, and about one minute with the hand blender blade!) When my youngest boys dropped ours, I gathered up the pieces of plastic that connect the attachments to the motor shaft, and carefully super glued them together. I then wrapped the plastic piece with fine nylon thread and a thin layer of super glue and placed it back onto the motor shaft, then let it sit for 24 hours. It is now permanently attached to the motor shaft and good to go. Too bad Philips doesn't care enough to support their customers with a part their engineers designed to break and save the rest of the product. I'll remember this about Philips products when I buy an HDTV.
Aug 14, 2008 | Philips HR1358 Handheld Blender
Replacing Black Plastic Coupling
The part number is Cuisinart SPB7-20TXN and can be found on amazon.com. If this part is broken you will need to remove the brass coupling. Make sure you turn it clockwise not counter-clockwise as someone mentioned.
May 25, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Blade not turning
the top rubber piece could be worn enough that it is not engaging the pitcher. look at it carefully and see if the "teeth" of the rubber disc on top of the base has not cracked and worn away. a picture of the new one can be seen on the parts websites to compare I spent $10.00 for my replacement but i found them at other sites for $6.00. you will need a very skinny 7mm open ended wrench to get the old one off and it is left handed threads that means clockwise will loosen not tighten the part.i ground down my wrench but an ignition wrench from an auto store will usually be thin enough to reach the flats on the shaft under the rubber disc
Feb 21, 2008 | KitchenAid KSB3 Classic Work Top Blender
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Moulinex DDF444 Optipro 6Speed Handheld Blender Logo
182 people viewed this question
Top Moulinex Blenders Experts
Ross Keen
Tom Chichester
Steve Luck
Steve Luck
Are you a Moulinex Blender Expert? Answer questions, earn points and help others
