Question about HP Office Equipment & Supplies
How can I install HP DJ1100c under Win7 x86
Very ole one but I have new catriges
    ????? ???????? Feb 20, 2012
    Thanks! But I use XP mode under win7 and it works fine. Case closed!
  • Jeffrey McDaniel Feb 20, 2012
    Nice did not thing of that one... :)
  • 669 Answers
This printer is not supported under windows 7. HP did not release drivers for windows 7.
Posted on Feb 16, 2012
2 Suggested Answers
Vanniar
  • 23 Answers
SOURCE: HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Posted on Nov 26, 2009
How to hp m1005 mfp scanned image save in a file in win7? Scan preview is seen but can't save
I use Foxit Reader
https://www.youtube.com/embed/7uBsDMDUToo
and pdf999 as an editor
C:\Program Files (x86)\pdf995\readme.html
when you install these programs PDF becomes an option and also a right click context, plus it comes up as a 'Printer'.
Having said that, HP should have a Save As, or should default to a saveable file. Once you have 'Scan Preview', you have to click 'Scan' because the Preview is what it is, just a preview so you can see coverage and rough indication how it will turn out.
Apr 11, 2016 | HP LaserJet M1005 All-In-One Printer
The printer is seying change cyan catrige
If you did not replace the cyan cart with a new one, the old one is likely empty, too. If it's a new one, take it out, and wipe the contacts off (also, some HP carts have tape across the contacts when new, and you have to remove the tape before installing the cart.)
Sep 12, 2014 | Office Equipment & Supplies
Questing for an SMZ1244TX v2 driver for Win7 32 bit(pref x64 but I ain't holding my breath), otherwise known as the SMC-EZ10/100 "Compaq Special". Card came out of an ancient Compaq Presario 5000 Seri
First things first, x64 is for a 64 bit platform which your OS isn't ,but secondly if this card is ancient then it probably won't be supported on that platform anyways. Lookup the driver for a x86 (yes it's a higher number but it stands for the 32 bit OS your on. Why? That's another story) once you find the x86 bit driver to install it, just put windows 7 into compatibility mode for the windows version that driver was meant for. Confirm the changes in the bios and everything should work.
Dec 09, 2013 | Computers & Internet
Konica minolta di 1611, di 2011 driver windows 7 32 bit. konica minolta di 1611, di 2011 driver windows 7 64 bit pozdrawiam Jarek
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Feb 10, 2011 | Konica Minolta Di2011
Hello, i just came home with a brand new ink printer HP Deskjet 1050. I installed all drivers and software (printer, scanner and some help software). when i connect it to my laptop, i receive a usb...
while installing u must get a message to connect the printers usb.
if u dont get so try the default printer driver with the OS. means dont install the cd which came with the printer istead go to startup, devices and printer and try alligning. might work.
Dec 06, 2010 | Computers & Internet
I have an HP D5360 printer on a dlink dpr-1260I
I believe your suspicion of driver/Win7 problem is right on target. Many manufacturers have not created / updated hardware drivers to work under the new Windows 7 environment - which is much more security focused than past versions have been.
If the driver you downloaded from HP has not been tested and certified to work under Windows 7, then you have a slim chance of getting the printer to work correctly, if at all. If the driver has been tested and certified by HP, then I would file a trouble ticket with them, describing the problems exactly. You may have discovered a bug in their driver that they could not / did not test for.
Jan 01, 2010 | HP Hewlett-Packard D5360 Photosmart Inkjet...
I have an HP D5360 printer on a dlink dpr-1260 wireless usb print server. I am using Win 7 pro. I get error 0x0000007a when I try to print to the D5360. When I installed the printer on local usb port, it...
Jan 01, 2010 | Brother MFC-8120 Printer
HP Laserjet 4300 - constant print problems - error 13.01.00
You probably have a scrap of paper stuck in the feed where someone has janked a piece of paper out.
Nov 18, 2009 | HP LaserJet 4300 Printer
656 hp deskjet does not print
please replace the catriges with new orginal before replacing please clean the catrige inner part with cloth+water then replace new orginal one and then on.
please check the drivers is installed or not
start-setting- control panel down-printer and faxes
check printer drivers is there are not
and then please check it is in ready mode or in pause mode
it should be in ready mode
please give first single page and what you wish
Jan 01, 2008 | HP DeskJet 656c InkJet Printer
51 people viewed this question
Seeker5211
Seeker5211
