Question about Symbol MC3090
Why does it lose network connection?
Dear all. Need help with my symbol mc3090. The network adapter fails frequently. Redid the settings, I changed the ip address and even swapped the network card. I have other MC3090 that are on the same network and have no problem.Thanks.
SOURCE: Symbol MC3090 Error while connecting
Uncheck the "Enable 802.11d" in the Regulatory segment of the Wireless Options.
Posted on Jun 30, 2008
SOURCE: How can i cold boot
press and hold 1 & 9 ,then press power.
Posted on Jun 24, 2009
ProfessorRE
  • 5 Answers
SOURCE: (WINDOWS XP) computer can't find driver for connecting to mc3090
I've got your answer!
Free troubleshoot, contact Lexicon Technologies.
Call: 1-800-678-1744
Email: techsupport@lexicontech.com
Web: www.lexicontech.com
Posted on Sep 10, 2009
  • 65 Answers
SOURCE: I want to bring a Symbol MC3090 into WIFI
You can accomplish this by using Fusion utility on your MC3090 I can provide steps necessary for this request. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Posted on Jan 25, 2010
  • 65 Answers
SOURCE: I have MC3090 with Adapter unavailable
First thing first, update firmware to latest, then see if adapter becomes available. I can provide steps necessary for this request. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Mc3090 CONTRAST ADJUSTMENT
Brightness can be adjusted by the hotkeys or within windows (system settings - backlight).
contrast can be adjusted with a potentiometer at the mainboard.
normally contrast does not change over the lifetime (my oldest 3090 is used 8h/day for 7 years)
some of the old 3090 have a CCFL backlight which dramatically losing brightness when getting old. you have to replace the tube or display unit.
Jul 09, 2012 | Symbol Motorola MC3090 Handheld Computer
Dear all I need help with mc3090. It crashes to almost any application. Even after the boot. After I made it without the battery for some time to return to work. Thanks.
you need to re-flash to O/S. If this fails then you have a main board/CPU Failure. If you need assistance with this please contact technical@codeo.co.uk
Aug 02, 2011 | Symbol MC3090
I have a symbol MC3090 which was working great for a year and today when i try to connect to DCHP it gives a cannot find IP address due to 'NIC card' or something to that effect the error comes and goes...
I had the same problem with a MC3070 and this is how I was able to solve it.
Find an MC3090 that is working and set it in the cradle attached to your PC.
Next open My Computer on the Scanner and go to the Platform folder.
In this folder you should see another folder called Fusion.
Open the Fusion folder then click on the the icon that says CBPCfg.
ColdBoot Cfg should pop up.
Click WLAN Settings and then click Save Current.
Save it to the device and then copy it to your desktop so it is easy to access when copying it to the device in question.
Once finished plug the broken scanner into the cradle and copy the registry file into the Application portion of your device.
Do a reboot with 1+9+power and it should work.
This is assuming the 3000 series scanners are all the same.
Nov 16, 2010 | Symbol MC3090
Dear all I need help in configuration of Scanner from Symbol MC3090. The scanner settings I could'nt change in the system or better: where can I change this settings? I want to scan a I2of5 Barcode which...
You would need to configure the application which are you using to scan, there is usually one default length for the barcode preselected.
If you are using ScanWedge, download the CtlPanel application, start it goto Scanner settings, decoders, I2OF5 and length. Dont forget to make the settings persistend
Jul 06, 2010 | Symbol MC3090
How to setup wireless connection
Hello prabap. To set up a wireless connection on your MC3090, it is quite similar to doing so on a Windows-based PC. Just use the stylus to select the WiFi icon on the bottom-right of the screen and select 'properties', 'options', 'configuration', or 'connect to/set up a wireless network'. Which one you'll see depends on your OS. Just follow the instructions in the menu, input your desired connection information like the network name, password (if any), and any other information that you may need to connect to your wireless. It is important to make sure you have all the details of your network for it to connect properly. In essence: just approach it like you're setting up a wireless connection on your PC and you can't miss. If you need more help, please feel free to send me a message or email. I hope this helps. Good luck!
Jan 02, 2010 | Symbol MC3090 Wireless Barcode Scanner
I have plugged in a wireless adapter for the 360 but...
A red steady light on the adapter means it is ready to be connected to a wireless network. If it fails to connect then the WPA key is not correct.
WPA automatically changes keys on a frequent basis for security purposes. So you need to take note of the SSID (wireless network name) and the Wireless security settings (WPA and passphrase) from the wireless access point/router.
Once you have the wireless network settings on the access-point/router, go to the System area to enter those settings.
If all settings are correct, exit the System area. Your console should now be connected to your wireless network.
Hope this helps! Good luck!
Oct 01, 2009 | Microsoft Wireless Network Adapter Xbox...
Sep 02, 2009 | Symbol MC3090 Mobile Computer
Need WIFI Configuration manual for Mc3090. Getting error "The Profile you are trying to Connect to May not Connect due to regulatory issues"
Have to go to Fusion > WCConfigure> Options > Regulatory > uncheck ENABLE 802.11d,
I assume that Fusion is installed on all MC3090's but if not, you are looking for the wireless configuration options.
Apr 14, 2009 | Symbol MC3090
Cradle and cable part numbers to charge a Symbol MC3090
u buy cradle for mc3090 .... it is so simple... u r boss may getting mess up with you
Oct 08, 2008 | Symbol MC3090
Mar 11, 2008 | Symbol MC3090 Mobile Computer
Symbol MC3090 Logo
441 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
