Question about Compaq Presario S5000NX PC Desktop
Cd burner i have an hp s5000nx one master one slave.the master went bad after 5 years of use,i un hooked the master took it out. made the the slave the master,my pc don,t recognize a writer on it.i use this pc for recording my own songs i write mr guitar
  • 903 Answers
It could be conflicting with the harddrive. If the hardrive is set to master then set the cd drive back to slave and try again.
Posted on Oct 25, 2008
Need diagram info for master and slave driver
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Dec 06, 2010 | Samsung TS-H492 (TSH492AWRBH)...
How to set NEC NR 7800A as the master
the First thing you need to do is make sure the jumpers on the back of the drives are set ,one to slave and one to master. there will be a mark either on the case by the jumpers or on a label on the drive. On systems I build
I set the top one to master and bottom one to slave. It makes it easier to hook up the cable to them. The end of the cable goes to the top one and
the other one to the slave.
May 15, 2010 | NEC NR 7800A CD-RW Burner
CD Rom - not working
It is possible for optical drives to fail. The easiest solution would be to try and reseat all the cables and attempt to read a known good CD-ROM with data on it. It it still fails, replace it. Most likely, due to the age of the computer, it has an IDE connection, not SATA.
If you replace it don't forget to place the master/slave jumper pin in the correct position.
Jan 09, 2010 | Compaq Presario S5000NX PC Desktop
Installed hp dvd r/rw drive, computer does not recognize hareware
You may want to check your Master/ Slave or CS settings on the back of drive.
If you are useing one cable, IDE cable for both the HD and CD, the Hard Drive sould be set to Master and the secondary drive ( CD ) will be set to slave.
If two cables are used, both should be set to master.
You can F-10 into your BIOS settings to check and see if machine is seeing the connection changes.
Sep 27, 2009 | AOpen ( 91.4ID37.074) (91.4ID37.074)...
CD ROM MODEL LTR-48327S IS MY CD BURNER WHEN I added a new cd/dvd player burner my cd burner quit working what is the problem?
each one has jumpers on the back. tiny plastic thing that slides over two pins. there are six pins. three sets of two. one device must be set to master one to slave or they wont work.
they are usually labeled with a picture or M S CS
master, slave, cable select.
Aug 22, 2009 | Lite On LTR-48327S CD-RW Burner
Won't reconize DVD burner
Well, the CD ribon cable goes into the IDE 2 slot on the Mainboard and the furthest connector on the other end is the master, the second one closest to the board is the Slave connector. The CD drive has a jumper on the back between where the ribbon and the power connector go, on the case some where it should have a diagram showing the jumper setting to put it in as master or slave. Set it accordingly.
Same with Hard drives.
If the Hard drive has a diferent Cable like a SATA, then be sure to get a SATA as the new one.
Now the IDE cables may be bad check them for damage just to be on the safe side.
Feb 04, 2009 | HP Compaq dc7100 PC Desktop
G4 350 mhz agp powermac
Can you try installing the new burner as a slave and the zip as the master?
Had a pc once that refused to boot at all with a new DVD burner in it, alongside a DVD-ROM. The burner was replacing a CDRW drive, swapped the drives master and slave settings over and it worked.
Oct 15, 2008 | Apple Power Mac G5 Desktop
Lg 20x external super multi dvd rewriter - not working
well, you can try taking the dvd burner out first and exchange places with the other burner. what i mean is may the dvd burner your primary master or slave. try it and post whats happens.
Jun 12, 2008 | Computers & Internet
Jumper Setting
* place cd /dvd burners in different channel
* hdd should be set master and ur one cd/dvd burner should be slave
* other cd/dvd burner should be master
May 27, 2008 | Microsoft Troubleshooting Your Web Page...
KHCRW 52 24 52 CD-ReWriter not recognized
Change the Jumper To Master Or Slave.
CS Is cable Select, your computer may not support this Option.
If installing on a cable with a drive, already connected. i.e hard-disk. if the hard-disk is slave set the cd rom to master.
Enabling both channels, is the 2 individual slots on your motherboard. Primary And Secondary. Or IDE 1 And IDE 2.
This will solve your Problem.
Mike @ compurepair.
Feb 20, 2008 | KHypermedia (KHCRW522452) (20326452) CD-RW...
Compaq Presario S5000NX PC Desktop Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
