Coffee Makers & Espresso Machines Logo
Posted on Feb 16, 2012
When I push power button household circuit breaker trips
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Feb 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
3326
Points
41
It is cuesed by a short, If the unit got wet, try drying it out for a few days.(not in the sun) with winds, Open as much holes in the unit as you can if after the drying it is still doing it this short is caused by an electric wire thatch loose...
Fix it by finding the wire or by taking in to an electrician...
Hope it helps
Finding the circuit breaker on my quantum Q6 power chair
From the owners manual;
Main Circuit Breaker (located on the rear main frame):
The main circuit breaker is a safety feature
built into your power chair. When the batteries and the motors are heavily strained (e.g., from excessive
loads), the main circuit breaker trips to prevent damage to the motors and the electronics. If the circuit
trips, allow your power chair to "rest" for approximately one minute. Next, push in the circuit breaker
button, turn on the controller, and continue normal operation. If the main circuit breaker continues to trip
repeatedly, contact your Quantum Rehab Provider.
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Our 7788F keeps going into a ground fault condition. Need help troubleshooting. John
Ground Fault ???
Troubleshooting Ground Fault
Troubleshooting a ground fault circuit interrupt, or GFI, breaker is pretty straightforward. Troubleshooting the circuit itself can be quite time-consuming.
The GFI breaker is designed with a test button incorporated into the breaker itself.
Pushing the test button should trip the breaker.
On GFI-style breakers the neutral wire going into the house's outlets is connected to the breaker's neutral connector, the white neutral that comes out of the breaker is connected to the neutral bus in the panel, isolating the neutral bus from the neutral wire going into the house.
The test button actually shorts the neutral wire feeding the circuit to the neutral bus in the electrical panel creating a ground fault that should trip the breaker.
It is considered a ground fault because the neutral bus in the main electrical panel is actually connected to the ground bus through the panel's metal casing. What to do if the test button isn't tripping the breaker
Push the test button on the GFI breaker.
The breaker should trip.
If the breaker does not trip, then it may be that the breaker has already tripped and just looks like it's on.
The position of the switch may only move slightly from the on position towards the off position when tripped.
Push the switch on the GFI breaker all of the way toward the off position.
It may take some force to get the breaker to reset.
Turn the breaker back to the on position.
When the breaker has been reset properly you should feel some resistance when pushing the switch back on.
3 Push the test button again and the breaker should trip.
If the breaker still doesn't trip then you should test for power at the screw connections inside of the electrical panel.
Remove the screw that holds the dead front covering the breaker's connections.
Remove the dead front cover.
Test for power with your voltmeter set on AC volts on the highest scale.
For a single pole GFI breaker, touch the black lead from the tester to the silver screw on the GFI breaker and touch the red lead from the tester to the brass screw on the GFI breaker.
You should see 110 volts on the tester. If voltage is seen but the test button won't trip the breaker, then the breaker is bad and should be replaced.
5
Test for power on a two pole breaker by touching the red voltmeter lead to one of screws with a black or red wire connected to it.
Touch the black lead to the other screw with a black or red wire connected to it.
You should read 220 volts or close to it on your voltmeter.
If you read voltage and the test button won't trip, the breaker is bad and needs to be replaced.
What to do if the breaker won't reset and keeps tripping when turned on
6
Unplug everything that is plugged into any of the outlets on the circuit in question.
Try resetting the breaker again by pushing the switch all the way to the off position and then turning it back to the on position.
If it won't reset and trips when the breaker's switch hits the on position, it could be a bad breaker or a problem in the circuit itself.
7
Use your straight-tipped screwdriver to loosen the brass connection screw or screws on the GFI breaker.
Pull the black hot wire, or wires, out of the breaker's connectors.
Loosen the silver screw the white wire is connected to and remove it from the GFI breaker.
8
Push the switch all the way to the off position.
Turn the switch back to the on position.
If the breaker still won't reset, then the problem is the breaker itself and it should be replaced with a new one of the same size, brand and model.
If the breaker resets normally and the test button trips the breaker when pushed, the problem is in the circuit itself and an electrician should be called to find your ground fault.
9
Reconnect the black wire, or wires, to the brass screws on the GFI breaker.
Reconnect the white wire to the silver screw on the GFI breaker.
10
Replace the dead front cover into the breaker panel.
Install the screw or screws that hold the dead front in place.
http://www.hilo-electric.com/blank?pageid=63
1helpful
We're is the fuse on the Jet 3
I hope this helps:
The main circuit breaker is located on the front of the battery tray.
Main Circuit Breaker: The main circuit breaker is a safety feature built into your power chair. When the batteries and the motors are heavily strained (e.g., from excessive loads), the main circuit breaker trips to prevent damage to the motors and the electronics. If the circuit trips, allow your power chair to "rest" for approximately one minute. Next, push in the circuit breaker button, turn on the controller, and continue normal operation. If the main circuit breaker continues to trip repeat- edly, contact your authorized Pride Provider.
Here is a link to the owners manual too:
http://www.spinlife.com/files/pride_jet_3_ultra_om.pdf
1helpful
I have a Whirlpool Cabrio dryer that will power on, but you can not push the start button. How is this fixed
Ok, I have the owner's manual in front of me and there are 5 possible causes for your problem.
1. Is the door completely closed?
2. Are you pushing the START/PAUSE until you hear the dryer drum moving?
3. Have you checked to see if a household fuse is blown or a circuit breaker has been tripped. Electric dryers need 2 household fuses or breakers.
4. Do you have a 240 volt power supply?
5. Are you using a tiime-delay fuse?
These are the possible causes and the solutions in the manual. I hope one of these is the right solution for your problem. I've never had this problem with my Cabrio so all I can do is give you the info in the manual.
I really hope this helps.If it does, please come back to Fixya and rate my advice. Thanks!
Jul 29, 2011 • Dryers
The display panel is blank, and none of the buttons work. It had been working earlier in the day, but is no longer functioning. Is there a breaker button?
Hi, Check to see if there are any lights working, such as the ones that come on when you open the oven doors. If there is absolutely no power going to the unit, check the household circuit breaker panel that services the oven.
An oven works at 240 volts so the circuit breaker for it will be a double breaker, similar to the ones
electric water heaters or air conditioning units. It may have tripped. If it is tripped, then
the lever connecting the two sides of the breaker will not line up with other breaker switches in the
breaker panel. If that is the case, shut down the breaker completely and then after about 10 seconds,
turn it back on. If it will not stay on, there is an electrical problem in the circuit going to the oven or the oven itself. Hope this helps. Let me know if your need more help.
Best,
Mark
My K5.20M power washer won't start. Am looking
Make sure your extension cord is able to provide 13 amps or greater of current. The longer the extension cord the more current it requires to supply the 13 amps to your power washer. If your unit has a long extension cord it could pull more than the typical 15 amps used for a household circuit breaker. If you do not have an adequate circuit breaker it will continue to trip. Now that you have the correct power supply you will notice the GFI Test and Reset buttons by the power washer plug. Plug the power washer into the power receptacle which has live power. Make sure the power washer is off and then push the reset button located on the power washer plug until you hear a click. The GFI should be reset and you can now turn on your power washer.
1helpful
Dryer not heating
Answer Did you select an Air Only cycle or Air Only temperature option?
The Air Only cycle or Air Only temperature does not add heat to the dryer. Expect loads dried with the Air Only cycle or Air Only temperature to take longer to dry. Air Only cycle or Air Only temperature can be found on the control knob or button with the other temperature selections.
Has a household fuse blown or has a circuit breaker tripped?
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuses or reset the circuit breakers. If the problem continues, call an electrician.
Did you recently install a power supply cord on the dryer?
The power supply cord may be incorrectly installed. Review the Installation Instructions to make sure that the power supply cord is properly installed.
Whirl pool dryer LEC9000PW0 will not turn on
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
David Kassin
David Kassin
Paula Hamilton
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
