Question about Leica C-LUX 3 Digital Camera
How to remove dust inside - Leica C-LUX 3 Digital Camera
    Problem Solver:
  • 17 Answers
Inside what? Most electronics u will have to use compresses air...
you can buy bottles of compressed air at car parts shops, just blow this in to all the holes you can find on Unit.
other option is compresses or Gas stations wheel pump...
Hope it help....
Posted on Feb 16, 2012
  • 93 Answers
You need a special bristle brush, it has very soft bristles and a small rubber balloon that you squeeze and blow air through the bristles and hence blow the dust away as you go.These are usually available from any camera shop.Regards
Dust inside screen
You would have to pull the case apart. depending on your tv you may also have to remove the lcd panel.
Nov 13, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Eureka airspeed one
DustcupScreen
Latch
Pull dust cup latch to release
dust cup. Remove filter and wash. Allow to air dry thoroughly (24 hours) before placing back in dust cup
Empty the dust cup into the trash container. Wipe debris off screen.
Hold dust cup handle in one hand and the bottom of dust cup in the other, turn dust cup counter clockwise to unlock the cup from the lid.
Hold dust cup handle in one hand and the bottom of dust cup in the other, line up arrow on dust cup with unlock icon on backside of dust cup. Turn clockwise to lock the cup to the lid.
Replacing the Belt
Unplug vacuum.
Recline cleaner back. Using Philips screwdriver, remove 4 screws from hood.
Using thumbs, push down on height adjust knob, while pulling up on
inside hood edges with fingers. Lift and remove hood.
Lift left side of brushroll out of
grooves. Then lift right side of
brushroll out of grooves.
Line up corners of hood and put hood tab inside the front of cleaner. From front to back, push hood onto base, keeping hood in base grooves, and line up 4 screw hol
Remove belt from the brushroll and motor shaft. Loop new belt over motor shaft and brushroll, onto grey belt pulley.
Jun 28, 2013 | Vacuums
How do i remove dust from a rear projection tv
If you mean is how to clean the inside dust?..You can used vacuum cleaner and brush to clean or remove the dust..
Dec 17, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
My fan wont stop running inside of my PS3 console. What is the best way to remove lint and dust from inside of my console? I would like to clean it myself.
Best thing to use for cleaning dust out of electronics devices is an air duster.
Example found here: http://www.maplin.co.uk/dust-and-dirt-removers-28999
You should be able to pick one up easily from a local computer or electronics store.
When you have it you'll just need to blast the air through some of the open vents to remove any built up dust.
Hope this helps.
Mar 15, 2011 | Sony Playstation 3 (PS3) Console
Dust filter has indicated extreme level of dust for several days making the fan stay on high. any way around having it professionally repaired?
- Remove the top two screws from the control panel.
- Remove the control panel. Be careful not to pull to hard as there is a ribbon cable taped into place.
- If the ribbon cable is taped, remove the tape and set down the panel as to not put weight on the ribbon cable.
- On the top left side of the unit (behind the dust sensor), there is a small box that is held in by a screw and plastic clips. Remove the screw and put tension on the clips so you can remove the box.
- there should be two holes in the box (one on each side), use a cotton swab and alcohol to clean outside and inside the box. I reached inside with the wet swab as far as it would reach.
- While you are in there, take some time to remove as much dust off of the front panel and anywhere else it may be.
That did the trick for me.
Dec 24, 2010 | Kenmore EnviroSense 85501 Air Purifier
There is dust inside the lens. how do I clean the dust from inside the lens?
Your projector needs little maintenance. The only thing you need to do on a regular basis is
to keep the lens clean.
Never remove any parts of the projector except the lamp. Contact your dealer if other parts
need replacing.
Cleaning the lens
Clean the lens whenever you notice dirt or dust on the surface.
• Use a canister of compressed air to remove dust.
• If there is dirt or smears, use lens-cleaning paper or moisten a soft cloth with lens cleaner
and gently wipe the lens surface.
Never rub the lens with abrasive materials.
Nov 27, 2010 | BenQ MP623 DLP Projector
How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Jul 03, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Want to dust bulbs and screen on inside. how do i take apart?
don't remove anything use a clean lense cleaning cloth that's all dust the mirror.
we us compressed air to blow out the dust
Oct 06, 2008 | RCA R52WM24 52" HDTV Projection Television
How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
Mar 08, 2008 | Olympus Camedia E-10 Digital Camera
Leica C-LUX 3 Digital Camera Logo
61 people viewed this question
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
Are you a Leica Camera Expert? Answer questions, earn points and help others
