Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Solder used on ICs
Is regular electrical solder ok to use on replacing ICs?
Thanks
  • 4,234 Answers
If it is designed for electronics, yes.
Dan
Posted on Nov 06, 2008
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Solder to use on ICs
no its best to use radio shack solder # 64-006 for electronic circuits.
Posted on Oct 26, 2008
Good morning, I have no hdmi sound or picture is it possible to repair this board? Thanks
Hello
Normally these type of boards will have SMD type [Surface Mount Device]; ICs will be diretly soldered to the printed circuit board. Most of them are soldered to it by CNC machines [Computer Numerical Control]; and cannot be replaced by normal desoldering and soldering methods. Most of these boards, say upto 98% must be replaced as card replacement. OK.
Mar 21, 2011 | Televison & Video
I can not get colors to converge the option does not come up in the menu
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 10, 2010 | RCA R52WM24 52" HDTV Projection Television
Can someone help Panasonic tv will not turn on power light 3 blinks and a pause (pt-53wx42-53
Hi
Thanks for using FixYa. 3 blinks issue means failed convergence (STK) ICs which needs to be replaced. To do this yourself you should require some basic knowledge about soldering-re-soldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Panasonic PT-53WX42 53" Rear Projection...
The color on my tv is all over the place. the picture is there but top portion and bottom portion is like a half moon type deal and will not line up-- please advise
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 09, 2010 | Sony KP-51WS510 51" Rear Projection...
Rear Projection - Color convergence/bowtie effect
Hi
Thanks
Rylee
Apr 04, 2010 | RCA HD56W66 56" HDTV
My RCA 52 is blurry
Hi
Thanks
Rylee
Apr 03, 2010 | RCA HD52W56 52" Rear Projection HDTV
There are 3 distinct colors showing up almost like a 3-D image. red, blue, and green. What is the problem and how much would it cost to fix in a RCA Projection HD TV 52 inch?
Hi
Thanks
Rylee
Mar 31, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a rca hdtv, model #hd52w59, chassis #itc222a, convergence is off real bad, happened all of a sudden, went to menu to set up and convergence is not showing, is there something special i need to do to...
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. The convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 23, 2010 | Televison & Video
Oct 25, 2008 | Toshiba 42H82 42" Rear Projection...
Color
Did you replace both ICs? If so check the solder connections if they are ok you may have the resistor that controls the blue vertical yoke open. Check the resistors for one being open if the solder looks good on the pins of the new ICs
Jun 02, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
